I take it you are talking about Meriva v Astra G?
They are not compatible - even if the eeproms are cloned. As far as I can remember the fuel pump enable is different (one is pin 23 and the other is pin 24). Thats not the main problem though, the clocks on the HSFI 2.5 vehicle are fed by CAN bus through the body control module and on the HSFI 2.1 the clocks have seperate wires from ECU to just turn warnings on and off (unless it is K-Line, but either way, the clocks won't work).
