Page 1 of 10 123456 ... LastLast
Results 1 to 15 of 137
    ruffles1986's Avatar
    Sep 2011
    In the Garage
    Default Need help Navigator Vw Golf code
    hello i have a navigation unit, i think is Mfd2, the label with serial number was erase, then i read with vag-com and said:
    1K0919887F
    I try to read with carprog clone, but not work, i think this unit is not supported.
    What is the best why to read this code or unlock solution??
    Faraday's Avatar
    May 2012
    The dark side of the moon
    read FIS post dump for code
    Sep 2011
    In the Garage
    Quote Originally Posted by Faraday View Post
    How can i read the FIS in thi unit? have you photo? thanks
    Faraday's Avatar
    May 2012
  5. The Following 3 Users Say Thank You to Faraday For This Useful Post:
    ali kaptan (3rd July, 2019), ruffles1986 (26th March, 2014), triak88 (15th July, 2015)
    Sep 2011
    In the Garage
    use search button been posted many times
    http://www.digital-kaos.co.uk/forums...grammer-54583/
    I already have navi crack software, but i don't know the exact type of this navi... MFD MDF2? have connector 18 pin not 26 pin connector.
    In pdf document in navi crack not appear the reference that through vagcom.
    Those units we read/write as a 24c16 eeprom include the following:
    3B0 035 186 C
    3B0 035 191
    4B0 035 192 A
    4B0 035 192 E
    4D0 035 192 C
    4D0 035 192 E
    8D0 035 192 D
    Those units we read/write as a 24c32 eeprom include the following:
    1M0 035 191 A
    3B0 035 186 D
    3B0 035 186 C
    3B0 035 191 D
    4B0 035 192 F
    4B0 035 192 H
    4B0 035 192 K
    4B0 035 192 L
    4B0 035 192 M
    4D0 035 192 M
    4D0 035 192 H
    7M5 035191 A
    7M0 035 191 H
    8L0 035 192 F
    8E0 035 192 B
    1J0 035 152 G
    1T0 035 194 A
    1T0 035 194 B
    1T0 035 095
    1T0 035 195
    7L6 035 186 A
    7L6 035 191 C
    7L6 035 191
    7H0 035 191 F
    I use search button for found image connection and software supported this unit, i found other post and have this two references :
    http://www.digital-kaos.co.uk/forums/f176/radio-navigation-1k0-035-198-b-bno-881-a-243157/#post1362284
    1K0 035 198 B BNO 881 7 612 002 064 WZ1Z7F xxxxxx
    Made in germany
    1K0919887F
    FIS 16/32
    audiopoint's Avatar
    Mar 2011
    MACEDONIA
    try this from NYO
  8. The Following 3 Users Say Thank You to audiopoint For This Useful Post:
    mcd76 (26th March, 2014), ruffles1986 (26th March, 2014), triak88 (15th July, 2015)
  9. #7
    Faraday's Avatar
    May 2012
    Open unit and make photo of bottom pcb.
  10. #8
    Sep 2011
    In the Garage
    Finally i read the dump as 24c32, the photo is that uploaded audiopoint
    I not modify pin with Navi crack because i think the dump is not correct...
    Can any extract pin code?
  11. #9
    Faraday's Avatar
    May 2012
    1431................................
  12. The Following 5 Users Say Thank You to Faraday For This Useful Post:
    Hayssam1 (25th November, 2019), kappa1 (27th March, 2014), mcd76 (26th March, 2014), ruffles1986 (26th March, 2014), smoggy (26th March, 2014)
  13. #10
    Sep 2011
    In the Garage
    Tomorrow i try and report. Very thanks
    Enviado desde mi GT-I8260 mediante Tapatalk
  14. #11
    Sep 2011
    In the Garage
    Work good. Thanks friend!
  15. #12
    Faraday's Avatar
    May 2012
    Need to thanks on MHH also!
  16. The Following User Says Thank You to Faraday For This Useful Post:
  17. #13
    audiopoint's Avatar
    Mar 2011
    MACEDONIA
    please code
    3B0 035 191 D
    fis 24c32
  18. #14
    prusony's Avatar
    Belarus
    -= 0947 =-
    Non ut edam vivo, sed ut vivam edo.
  19. The Following 5 Users Say Thank You to prusony For This Useful Post:
    audiopoint (3rd July, 2014), bogege (3rd July, 2014), nelutzul40 (3rd July, 2014), REZON (3rd April, 2015), smoggy (3rd July, 2014)
  20. #15
    Apr 2011
    need code for Blaupunkt Navigation
    Read FIS 24C32
    Thanks in advanced
    Mat
