irishvamp (2nd August, 2015)
updated guys do a scan after installing new list cheers
new list updated cheers
updated as always scan after cheers
How do I install this on my Dreambox 500s? Im using a tool called FlashWizard PRO 6.3. It sends the file called 'bouquets.tv' successfully but when I look in my bouqets there's nothing there?
These are Enigma2 bouquets so will work but none of the HD channels will show for obvious reasons, My advice to you with a DM500s is to install this: Commmando image
Everything is built in Autobouquets 7 day epg etc.. i shall put it this way if Carlsberg did images for the DM500s then it would be this image
Thanks digicon I tried that but I get an error in FlashWizardPRO saying 'it's not a firmware that can be installed in flash. It is too big for flash memory, try to install in multimode'
When I try in multimode I get this error 'Multiboot disabled: unable to install: no devices found or all are disabled'
I cannot comment on the program you are using for uploading the image but i use dreamup 1339 with null modem and have never had a problem on any DM500s
elrasho (29th August, 2015)
there are enigma 1 bouquets on this site @elrasho as this is enigma 2 it wont work on the dm500 unless you use drwambox edit and change it to use in enigma 1 boxes also no hd on dm500 cheers
Thanks looks like I need a RS232 cable to upload the Bouquets. I was hoping I could do it using a network tool of some kind.
elrasho (31st August, 2015)
