Page 2 of 95 FirstFirst 12345671252 ... LastLast
Results 16 to 30 of 1424
  1. #16
    magnacin's Avatar
    enclosed are 2 images of galletto v54 I bought from china last week and got it yesterday. I don?t know if there is a difference with version 53. As for the software I am having some trouble installing it cause there is only 2 files. It installs ok but when try to run I cant do it. I am working on it. Please, if somebody can help me with this I greatly appreciate it.
    Thanks.
    "I find your lack of faith disturbing"
    If you found my post useful, please use the "Thanks" and "Rep" buttons.
  2. The Following User Says Thank You to magnacin For This Useful Post:
    Mrrob (13th September, 2017)
  3. #17
    Jun 2013
    EU
    Can't understand why the hell they pour that shit over the PCB, afterall its a clone and well known. No secrets there, just different bin in MCU regarding V53.
    I would not buy poured with shit fgtech, imagine it fails and you need to repair.... ufff
  4. #18
    Nov 2013
    [QUOTE = magnacin; 2271797] Ciao,
    racchiusa sono 2 immagini di galletto V54 ho comprato dalla Cina la scorsa settimana e ottenuto ieri. Non so se vi ? una differenza con la versione 53. Per quanto riguarda il software che sto avendo qualche problema l'installazione perch? c'? solo 2 file. Si installa ok, ma quando tenta di correre non posso farlo. Sto lavorando su di esso. Per favore, se qualcuno mi pu? aiutare con questo ho molto apprezzato.
    Grazie. [/ QUOTE]
    Hello charge the full software they gave you, so I'll give you help about installing ok?
  5. #19
    magnacin's Avatar
    I have installed the software I will try to test with car later and upload file for compare purposes. Actually it was pretty simple to install. First install galletto app, the install galletto win7 app. That is it.
  6. #20
    Nov 2013
    Quote Originally Posted by magnacin View Post
    Hello you kindly post or send me in private, all the contents of the installation of your galletto for windows 7? Thanks in advance.
  7. #21
    magnacin's Avatar
    Here is a file read. Ibiza 2005 2.0lt Petrol benzina ME 7.5.1 can somebody please verify that file is ok?
    Thanks.
  8. #22
    Nov 2013
    [QUOTE = magnacin; 2272227] Ecco un file letto. Ibiza 2005 2.0lt benzina benzina ME 7.5.1 qualcuno pu? per favore verificare che il file ? ok?
    Grazie. [/ QUOTE]
    Hello the file is ok but could you kindly send me the installation file that you found in the box of your FGTech V54?
  9. #23
    Apr 2011
    Quote Originally Posted by infinityecu View Post
    Grazie. [/ QUOTE]
    look at post #9 .iso 135MB
  10. #24
    Nov 2013
    Quote Originally Posted by SandroMarciano View Post
    Thanks a lot
  11. #25
    Nov 2013
    [QUOTE = SandroMarciano; 2273345]. Guardano post # 9 iso 135MB [/ QUOTE]
    Hello but you have tried to install it on win 7?
  12. #26
    mexanico1971's Avatar
    portugal
    Thanks.
    Hi !
    what"s is your tool number ?!
    can you read the 2 files of FTDI for share ??!
    thank"s in advance !
    Br
    My work is my life ART TECH GARAGE
  13. #27
    My galleto 3 with this v54 Software , the sofware open but not show voltage, i think v54 use other ftdi files.
  14. #28
    magnacin's Avatar
    Default Can't write to ECU
    Please a little help. I tried to write a file to a Peugeot 206 1.6 petrol ME 7.4.4 This file I have been using for some time, but what I did before is to remove EEPROM and program with programmer and then resolder to ECU. File worked ok. But now that I try to use galletto I get the following message: Writig initialization... reading error or wrong file dimension. I am including the file if someone can review it or has a solution to it. According to galletto cheksum appear as ABC0. I don't know if its is file problem or tool issue. Any advise on how to correct issue.
    Thanks for your help
  15. #29
    you need to read and edit. Youre probably trying to write a different software version
    Pro VAG Petrol Tuning | Pro DPF Removal | MED17 TPRot Removal
  16. #30
    Nov 2013
    Are you trying to write the file over obd which you have read from bdm?
