Flash erase DM 7025 ?
Results 1 to 15 of 17
    Jun 2009
    Question Flash erase DM 7025 ?
    How do I flasherase my DM 7025 ? I think there is som old crap on it. I`ve tried to push the up button when booting up after installing a new image, but nothing seems to happen.
    DK Veteran on_the_jazz's Avatar
    Jul 2008
    Quote Originally Posted by tdolan View Post
    There is an erase image on here somewhere. I'll edit my post in a minute if I can find it.
    edit: Had it on my usb stick, I've attached it. I believe I downloaded it from a post by Curious123, so thanks to him too.
    V.I.P. Member Curious123's Avatar
    Apr 2008
    You should only need to use this erase image file if you are having problems flashing your box but also I think this file is only for a dm500. You will need Dreamup and a null modem cable to flash the box. When you start the Dreamup program you need to check or press one of the buttons marked 'flash erase'.
    Jun 2009
    Is the flash erase in the zip file for DM 7025 or DM500. I`ve have to be sure, before I dare using it.
    Dreambox Guru osborne82's Avatar
    Mar 2008
    any dreambox development forum
    if its a .nfi image then its for the 7025 if it ends in .img then its for the 500
    cheers
    osborne82
    Jun 2009
    There is no extention on the uzipped file, it`s only a file.
    Not a .nfi or a .img, so I still haven`t solved my problem. Please help me.
    Some time ogo I had an erlier version of dream up, and there was a button to erase.
    In the newer versions they have removed this button, why?
    If I find it, can I still use it?
    The earliest version I have is a 1.2, with no erase button.
    V.I.P. Member despdan's Avatar
    Midlands Ireland
    Can you not preform a flash erase when flashing another image?
    Jun 2009
    That`s why I ask these questions. I`m not shure how to do it. I have flashed several image to my box, LT, Peter Pan, and almost everything I could find, to find the image that suits me best, and also it`s a nice hobby. The last 1/2 year, all different images have run unstable, I`ve even took out the hdd and have ordered a new one, since I could not format it. I`m not quite sure if I am dealing with 1 or 2 problems here. That`s why I like to flasherase my box, to start with a clean image, without any old crap.
    Midlands Ireland
    It give you that option when you connect the box in DreamUP.
    Are you flashing them to the box or multibooting them from hard disk.
    Could you explain in more detail? Might be something else.
    Jun 2009
    I can`t se any choice in DreamUP 1.2 and upwards. Maybe it`s because I hocked the hhtp. Do I get this option if use the slow method with the rs232 with O-modem cable ?
    I flash direct to the box, no multibooting or Barry Allen here.
    The images runs better without the HDD. Could not initziate it in several images, so I took it out, maybe it is damaged.
    I wil put it in my PC and check it out. I am more at home on my PC, than in Linux on my Dreambox. But I`m learning a bit every day.
    PS. I like this forum, quick answeres. Thanks.
    Default dm7025
    is this for dm7025
    Mar 2011
    Okee it works
  13. #13
    Sep 2008
    Default erase_image.zip
    can some one upload erase_image.zip for dm 7025 as the one thats on hear dont work thanks
  14. #14
    Mar 2011
    Quote Originally Posted by bog1 View Post
    yes please!!!!!!!!!!!!!!
  15. #15
    Nov 2010
    thanks you
