sorry i dont mean to be a irritation but does anybody have a solution?
Try its, and You need clear fault of scaner. And pls write full name of MCU: XC2060-?? (XC2060-40 for example). And post full damp, if You can read its
As all times: no result, no answer
try and report
should be all ok
pass in pm
[Please help for same airbag ECU AB39-14B321-CE
test and report
pass pm
matej12 (1st December, 2015)
Thank you, next day tested nand report
Super, work ok. Thanks verry much
Hello I've got the same airbag ecu AB39-14B321-CE Never done this one before... Can someone please help me clear crash data?
Thanks on advance.
Hello!
Can somebody help me to clear this airbag?
Thank you!
Cristi
SOLVED
Please try to clear my ford ranger file.
AB39-14B321-CE FORD RANGER
Your file cleared
test and report
regards
slick
pedjica (29th May, 2018)
He wrote that the problem is already solved
not work b1193 crash event storage
