Vauxhall/Opel - Letters on ecu ? HELP
    Jul 2013
    Lublin
    Default Vauxhall/Opel - Letters on ecu ? HELP
    Any one now what the letters means on the ecu ?
    For example DRTJ and DJTY different letters but same numbers 09353509 . From engine Z14XE and Z16XE !
    Are they will fit any engine Z14XE or Z16XE ?
    Any one got any list of them ? How to match them , what is important on ecu ?
    I know some of them coming without A/C and some with
    Please Help
    Thank you
    Aug 2011
    Spalding
    Hello
    I fitted a Z16XE engine into a Z14XE car. The Z16XE ran fine with the Z14XE ECU that was already in the vehicle.
    Not the same as you are asking, but it looks promising to swap them over as both engines will run the same ECU.
    Well they did in my case.
  3. The Following User Says Thank You to MJRVR For This Useful Post:
    Dunker (29th June, 2018)
    Mar 2013
    Bump !
    These are software versions for Z16XE ,does anyone knows which one has Air Conditioning ?Thanks !
    DZJT 12249813; DMKP 09353489; DHUD 09353489; DJTX 09353489; DNHN 12214870; DSBH 12223650; DXMF 12242040; DZJU 12242040; DPAB 09353489; FBWN 12249812;
    Denmark
    u can swap soft and epprom between this 2 ecu u can allso switch ac on whit opcom
  6. The Following User Says Thank You to turboracing For This Useful Post:
    TR0UBLESH00TER (30th June, 2018)
    racin-snake's Avatar
    Jun 2009
    You can swap ecu then SPS it to your original VIN with tech2 THE EPROM is not changeable this is a hybrid ecu HSFI 2.1 ... if you can get pin code from used ecu reset and marry it to your vehicle change VIN and SPS it to your VIN
    Today is the Tomorrow you worried about yesterday ......Was it worth it ?
  8. #6
    Aug 2018
    East Pole
    Hello, turboracing, agree with you, but it depends on how the ac module works. There are 2 variamt of cooling with one or two cooling fans. So, there might be differences on the ac module and year versions. There is no difference on the hsfi 2.1 model/numbers and letters. It is the same platform on all. By reprogramming the new one/scrapyard one(clonimg flash and eeprom), you can have the same ecu as the old/broken one from your car.
