Anyone habve dumps,flash or eprom for this module of parking sensors?
Have DTC EEprom error.
volodea28 (17th January, 2024)
Hello.
I know this is an ancient thread, but maybe someone will find the answer usefull. I don't know if it applies only to this type of parking aid module, but it is worth a try if you have same error.
After searching and reprogramming the module with different flash and eeprom info posted from other helpfull people , nothing have worked for my parking aid module , so i tried different things , and this one had success.
In Eeprom dump , after address 0151h i have filled all addresses with FF's , also 0152h - 07FFh = FF. This, worked for me 4 times with this type of parking aid module for Tiguan. maybe it will work for others modules with same error.
I attach original flash and Eeprom , also modified Eeprom .
abidinusta (28th February, 2019), AGK (12th November, 2020), Cadyady (30th January, 2018), cido123 (31st January, 2019), dorcky (7th February, 2018), dzevad (23rd September, 2018), Elektrik001 (29th April, 2021), HeXeN (25th January, 2022), illestibor (3rd July, 2018), iuliannj (18th January, 2022), lechus111 (6th March, 2020), MahoJohn (4th November, 2022), nazaeas (12th February, 2018), Nezakabude (28th June, 2023), pedjica (8th February, 2018), Resko (23rd August, 2018), seal777 (22nd March, 2023), spido (17th March, 2018), tzwetomir (13th October, 2021), Vivien Herold (1st January, 2022), vreditel (21st December, 2017), Zalizo (13th November, 2023)
Sounds good to me (my parking assist system just beep after moving to the reverse position). But I have no idea about how to write the EEPROM into the device. Any one can help about this ? (Or I have to check what the real reason is ? I have checked the voltage is 12V to the sensor, but no click sound from all the 4 rear sensors. It's something strange.)
Hello Ollync, thank you for sharing the info, i have the same module and the same problem.
can you tell me if I will be able to use USB eeprom / flash 24/25 CH341A to fix the eeprom error?
thank you!
