Enigma Images - Page 2
Page 2 of 5 FirstFirst 12345 LastLast
Results 16 to 30 of 70
Thread: Enigma Images
  1. #16
    aftermath's Avatar
    Mar 2008
    Quote Originally Posted by catseye View Post
    Has anyone got this working yet ive tried 4 times to load it -everytime it stays on 'booting' on front screen
    Ive renamed image to update & using PUTTY tried to alter settings still no luck
    I think i revert back to latest sif team image & wait for the straightforward usb flash version - if there ever is one!
    Catseye, ive never hat the time to try this way m9, but i can say this is the best one ive seen so far http://www.digital-kaos.co.uk/forums...r-1-0-a-19031/
  2. #17
    DK Veteran catseye's Avatar
    Nov 2008
    England
    Thanks for the advice aftermath
    Ive seen & read through the brilliant guide that sotiris70 wrote & published on here on installing enigma 2
    Im fairly confident of installing enigma using his guide but must admit i dont know what a nfs server is- is it something thats part of linux operating system on the IP Box 9000/Cuberevo?
    Ive got null modem cable & usb sticks ( sandisk 2gb or data traveler 8gb)
    I havent got a HDD installed yet (i have one, ATA/IDE & im trying to establish with i can get some cables/adaptors to make it work with SATA connections -now thats another story!
  3. #18
    Is it possible with this image on a USB stick to change the box IP after installation? I have got dual boot working well with the latest SIF image in flash and used the 9000-usb_config_welcome.img image from SIF to boot engigma but that method does not allow changing the Enigma IP
  4. #19
    aftermath's Avatar
    Mar 2008
    Hi Catseye, if you download partition manager, i think there is a link in ipbox tools.
    then you will be able to partition and format your 2gig USB stick, maybe partition in 2, use first partition for ( linus ) format to EXT2. and name partition XSYS1, you can use the other partition as nowmal for your ordinary files that way, but once you format the first partition to ext2 , windows will not be able to read it and wont detect that partition.
  5. #20
    aftermath's Avatar
    Mar 2008
    i am afraid you will have to change the uboot loader to the different IP address.
  6. #21
    Thanks aftermath, have tried editing 9000-usb_config_welcome.img with notepad and insering the correct IP,s uploading fails with a CRC fail. If I use fw_setenv commands they also fail with a CRC fail. Any ideas how to progress?
  7. #22
    aftermath's Avatar
    Mar 2008
    Default Enigma 2 Sifteam release 0.2.0 for IPbox 9000
    ENIGMA 2 for ipbox HD/cuberevo/cuberevo-mini SIFTeam:
    First boot take a little bit much more than a normal boot, so wait until you can see the bandeau bar (the one with infos on current channel) on the tv screen.
    WARNING: Do not forget to change your DNS configuration (if you want to use the decoder on the net). The DNS configuration could only be made by editing manually the file "/etc/resolv.conf"
    HISTORY:
    release 0.2.0:
    Bootargs are changed a little bit (simply removed the bygphysarea param), you can use the old one, or update them (doesn't matter if you update 'em or not)
    What's new:
    - support for:
    - cuberevo-mini2 (cuberevo-3000HD/ipbox 910HD)
    - cuberevo-mini (ipbox 900HD)
    - cuberevo (ipbox 9000HD rel1 and rel2)
    cuberevo-250hd (ipbox 91hd) and 200hd are not yet ready, i need more time, sorry
    - support for multple tuners:
    - dvb-s2 (samsung and new sharp tuners)
    - dvb-s
    - dvb-t
    - dvb-c
    - fix in epgcache to solve greenscreen in EPG->Similar Events
    - improved resynchronization after fast forward
    - added audio track selection for m2ts/trp/vob, after changing the audio track it might take 2-3 seconds for the sound to continue
    - tuxtxt dont crash if no swap is used
    - pictureplayer in fullscreen
    - networktest working (not yet enabled the possibility to change by menu ipaddresses)
    - added power-off function (to be tested better)
    - busybox +ip addr +nslookup
    - more exact seeking for m2ts/trp/vob on keys 1/3 4/6 7/9
    - added mkv support
    - volume up/down fix
    - added dts playback
    - support for twin tuners (to be tested better, working only live channels)
    - added seeking with 1/3 4/6 7/9 keys for some avi files
    - many HDMI related fixes
    - added m2ts and trp file extensions support in mediaplayer
    - Fixed CVBS, RGB, S-Video switching SCART mode
    - Enable choose ColorFormat for HDMI, set Component to ColorFormat YUV as default
    - added HDMI-PC custom resolutions
    - fix the pictureviewer
    - fix placing video picture on screen for Pig render. Skins with small video window now works.
    - scart set widescreen flag if wanted
    - fixed timer-bug
    - mpeg-1, mp2, 23.976 fps work
    - fixed the problem with low-bitrate streams
    - aspect fix for channels like BBC HD with resolution 1440x1080
    - mute should now work
    - added streamproxy for streaming channels via lan
    - changed webif to port 80
    - fixed webif in many parts
    - support for HD-Skins
    - support for HD-Picons
    - pyopenssl added
    - fix dvd-player
    - fixed HMDI, Scart detection
    - firstboot will be done by Wizard
    - fixed audio dropouts and video artefatcs
    - fixed many remote controller handling (all buttons should now works)
    - fixed possibility to change audio on channels by remote controller
    - SPDIF out should be fixed
    - added python bin
    - fixed hdd format
    - fixed hdparm (for hdd standby)
    - default language is fixed to English
    - added pl2303 driver (for external smart card reader)
    - updated polish language (thank's to zbigzbig and crashs)
    Consider also that any kind of mods are enabled, so everybody can do their own image, but please do not delete thanks and readme file.
    All people collaborating had worked hard, so please let's have a little respect.
    release 0.1.0(beta):
    This is the first public release, it's released as a beta version, probably it has many and many bugs, but to fix and to discover them I need all your help, so I decided to make it public
    This version does not support:
    - card reader
    - DVB-T, DVB-C, DVB-S tuners
    - twin tuner
    Enjoy it! Tideglo
    ABOUT ENIGMA 2 for ipbox9000/900/910/cuberevo/cuberevo-mini:
    This is an adaption of Enigma 2 for the DGStation's High Definition boxes.
    I want to thank these people:
    Team DuckTales: for helping me on finding really many bugs and to helping me on make Enigma2 like it is now.
    zbigzbig20, crashs: for default bootlogo
    Spaeleus: for Italian translation
    SIFTeam: this is my place, with all my friends that i like really to chat with!!!! (I LOVE YOU GUYS)
    I want also to thank two special friends:
    genge: for be the best betatester of ever!!!!! (really a ball breaker but also a good friend )
    PhotosOfGhosts: for helping me on finding, studying and solving bugs
    Regards, Tideglo
    HOW TO INSTALL:
    To test this enigma2 image you need a running nfs server and a serial & network
    connection to the receiver.
    You need uboot 1.3.1 or higher to run e2 (never tested with lower versions)
    Do this only if you want to use nfs-server otherwise go to point 3:
    1. extract the tgz file on the server and set the directory in /etc/exports
    for example:
    /root/Desktop/root 192.168.1.0/255.255.255.0(rw,no_root_squash,sync,no_subtree_ch eck)
    where 192.168.1.0 is your net base-address and 255.255.255.0 is your netmask
    2. restart nfs server
    3. connect via serial console with an hyperterminal connection to the receiver (I suggest you to use putty, it's freeware, and configure it to use a 115200 serial connection)
    4. turn on the receiver and hit ctr+z in serial console
    you should see the following prompt:
    cuberevo>
    5. customize the following settings to your network environment and type them into the
    serial console:
    codice:
    setenv menu_1 'setenv ipaddr 192.168.1.5;setenv serverip 192.168.1.6;setenv gateway 192.168.1.1;setenv netmask 255.255.255.0;setenv bootargs "console=ttyAS1,115200 panic=3 root=/dev/nfs nfsroot=/root/Desktop/root rw rootpath=/root/Desktop/root ip=$ipaddr:$serverip:$gateway:$netmask mem=128m coprocessor_mem=4m@0x10000000,4m@0x10400000 init=/bin/devinit";setenv bootcmd "nfs a5ff0000 192.168.1.6:/root/Desktop/root/boot/uImage;bootm a5ff0000";saveenv;boot'
    setenv menu_2 'setenv ipaddr 192.168.1.5;setenv serverip 192.168.1.6;setenv gateway 192.168.1.1;setenv netmask 255.255.255.0;setenv bootusb "run bootargsusb;usb reset;ext2load usb 0:1 a5ff0000 boot/uImage;bootm a5ff0000";setenv bootargsusb "setenv bootargs console=ttyAS1,115200 panic=3 root=/dev/sda1 rw rootdelay=10 init=/bin/devinit ip=$ipaddr:$serverip:$gateway:$netmask mem=128m coprocessor_mem=4m@0x10000000,4m@0x10400000";setenv bootcmd "run bootusb";saveenv;boot'
    setenv menu_3 'setenv ipaddr 192.168.1.5;setenv serverip 192.168.1.6;setenv gateway 192.168.1.1;setenv netmask 255.255.255.0;setenv bootusb "run bootargsusb;usb reset;ext2load usb 0:1 a5ff0000 boot/uImage;bootm a5ff0000";setenv bootargsusb "setenv bootargs console=ttyAS1,115200 panic=3 root=/dev/sdb1 rw rootdelay=10 init=/bin/devinit ip=$ipaddr:$serverip:$gateway:$netmask mem=128m coprocessor_mem=4m@0x10000000,4m@0x10400000";setenv bootcmd "run bootusb";saveenv;boot'
    setenv menu_4 'setenv ipaddr 192.168.1.5;setenv serverip 192.168.1.6;setenv gateway 192.168.1.1;setenv netmask 255.255.255.0;setenv bootargs "console=ttyAS1,115200 panic=3 root=/dev/mtdblock3 bigphysarea=1500 ip=$ipaddr:$serverip:$gateway:$netmask quiet";setenv bootcmd "bootm a0060000";saveenv;boot'
    saveenv
    remember to customize where /root/Desktop/root is the directory you added to /etc/exports and ipaddr is the ip of your decoder, serverip is the ip of your nfs-server, gateway is your gateway ip, netmask is the mask of your home-net
    6. now you can restart your decoder and press the relative remote controller's button for 5 seconds to start the image you want:
    Press Button 1: start your image using nfs-server
    Press Button 2: start your image using usb pendrive if you don't have a SATA hdd
    Press Button 3: start your image using usb pendrive if you have a SATA hdd
    Press Button 4: start your original flash image in the decoder (DGStation's original firmwares and images based on them)
    That operation is necessary only the first time you want to change your boot commands. You don't need to press all the time you reboot the decoder a button to select wich image to start, simply do that only if you want to change to e2 nfs from usb, or from original images.
    That's all, Tideglo
    Download here for the flash version
    or
    here for the USP stick method
  8. #23
    Mar 2008
    Aggiornamento del 03/02/2009 ---------->Nuovo file rcs che risolve il problema del restart gui.Sostituitelo in /etc/init.d .Date chmod755 e riavviate
    Update: 03/02/2009---->New rcs file that fix restart gui bug........Download it and overwrite in /etc/init.d .Chmod755 and reboot.Now it should work
    thanks to pkt polish team
    RapidShare: Easy Filehosting
  9. #24
    aftermath's Avatar
    Mar 2008
    Default Enigma 2 Sifteam 0.2.0.Mod PKT beta 3
    Hi again. And again new mod of latest Sifteam E2 beta 0.2.0 image for Ipbox 9000HD from Polish Kathrein team
    This image is for USB Stick. Install like prevous "PKT MOD" You can format your Usb stick in ext2 or ext3 fs (I prefer ext3 but It's only your decission) PKT panel menu is of course under "Blue Button"
    What's new:
    - based on New Sifteam Enigma 2 beta 0.2.0 (Thx Tideglo and other for great job)
    - fixed rcS for restart Gui BUG
    - added automaticly start emu after reboot/restart e2
    - on PKT Update server Updated:
    * Mbox to new version 0.21 ru5
    * My (zbigzbig20) settings for Rotor from 28.2E to 8W (soon another update)
    * Polish locale for polish users
    - and few other small fixes
    Many Thanks to zbigzbig20
    Download from here
  10. #25
    Nov 2008
    Default E2 rel 0.2.0 Tideglood PKT - mod DDTKLAN - for USB 900/9000
    If you already have hard disk with DGS image in flash you will not lose your data and you'll be able to watch your old recordings with new image too (hard disk is automatically mounted: /dev/sda2 on /mnt/hdd)
    If you don't have hard disk let me have your feedback here.
    1. Usually exctract image on USB
    2. Edit the file /etc/resolv.conf (default is 192.168.0.1)
    3. Start image from USB
    4. Download, using remote, your preferred emu
    5. By default, videomode is on SCART. You can change using remote.
    - Busybox 1.11.00
    - now we mount hard disk as sd2, just for compatibility with DGS images
    - ipkg (only in Telnet)
    - e2_loadepg by ambrosa
    - crond
    - server ddtklan for upgrades
    - small fixes to remote control
    - samba server (can be downloaded and installed by remote control)
    - fixed clock on display when in standby
    - italian channel list
    - picons
    - fixed other small bugs
    http://www.upload-drive.com/8025/E2_...od_DDTKLAN_zip
  11. #26
    aftermath's Avatar
    Mar 2008
    @zx1 it says invalid file .
  12. #27
    Nov 2008
    Default http://www.upload-drive.com/8025/E2_SifTeam_0_2_0_mod_PKT_mod_DDTKLAN_zip
  13. #28
    aftermath's Avatar
    Mar 2008
    Default Enigma2 for Ipbox 900/910 HD
    Enigma2 SifTeam 0.2.0 mod PKT beta 3.0b for Ipbox 900/910HD
    What's new:
    * settings for Rotor from 28.2E to 8W (soon another update)
    Thanks for PKT & Sifteam & TDT for great job
    Ipbox 900 here
    Ipbox 910 here
    follow same instructions to install as the IPbox 9000
  14. #29
    aftermath's Avatar
    Mar 2008
    Default Enigma2_ 0.3.0 PKT_ 3.3
    Enigma2 od Tideglo mod PKT v.3.3
    release 0.3.0:
    Now there's no more need to change bootargs, IPs will be set on Enigma2 Network Menu.
    Bootargs are changed a bit more if you do not want to set anymore IPs on bootargs. Bitwise also old bootargs will work perfectly.
    What's new:
    - support for:
    - cuberevo-mini-fta (cuberevo-200Hdt)
    - cuberevo-250HD (ipbox 91HD)
    - cuberevo-2000HD
    - cuberevo-7000HD/9500HD
    - added support for Common Interface modules (take in consideration that a CI cam will make slower Enigma2,
    this will be fixed in future. Also do not forget that to the upper slot will work with Tuner1 and lower slot with Tuner2)
    - fix for CSAT France HD Blackscreen
    - fixed randomly occuring crash on e2 exit
    - fix restarting if old timer still set
    - fixed front panel display management
    - fixed hour display
    - fixed stanby
    - fixed deepstandby
    - fixed restart GUI
    - fixed restart
    - fixed HD channels bugs
    - fixed many of the random artefacts on viewing channels
    - changed keymap.xml, now we will use the Enigma-like functions for remote controller buttons
    - updated cvs to 09022009
    - added srt subtitle support
    - added avi x264 support
    - added avi h264 support
    - added xvid 720p support
    - fixed mv id3tag
    - added wav support
    - added 2nd scart input control
    - fixed many HDMI bugs
    - fixed fast forward, fast reward
    - fixed audio track selection m2ts/vob/trp
    - added CROND and CRONTAB
    - fixed configuration Menu Network Setup (this will works only with USB and Flash version, NFS couldn't set IP for obvious reason)
    - added tun.ko module (for VPN support)
    - added/updated usb-serial converter support (pl2303, ftdi_sio)
    - added ssa subtitle
    - fixed ass subtitle
    - enabled ntfs as module
    - fix for HD skins
    - fixed mkv + h264 sync
    - implemented mp3 playback directly via http connection for plugins like last.fm
    - added filextension pls
    - fixed crash when tuner is not configured
    - fixed crash when harddisk or stick connected
    - fixed DVB subtitle position for HD skins
    - fixed crash on entry manual tuning parameters when S2 is in use
    - updated webif
    - fixed support for large file playing
    - fixed all scan problems and "No SID found in PAT" message
    - support for Unicable/SCR based system
    - many code optimizations and personalization for Cuberevo
    Tuxtxt is enabled but not yet working good on the "pressing button" recognition, so pay attention on using it, you will need to restart e2.
    Download the 9000 version here
  15. #30
    aftermath's Avatar
    Mar 2008
    Default E2_0.3.0_PKT_3.3 900 and 910 versions
    release 0.3.0:
    What's new:
    - support for:
    - cuberevo-2000HD
    - fixed stanby
    - fixed deepstandby
    - fixed restart GUI
    - fixed restart
    - fixed mv id3tag
    - added wav support
    - fix for HD skins
    - updated webif
    Download the 900 version here
    Download the 910 version here
