Enigma Images - Page 3
Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 70
Thread: Enigma Images
  1. #31
    aftermath's Avatar
    Mar 2008
    Default Enigma2 Tideglo 0.3.1 mod PKT 3.4
    - fixed the recognition of the DVB-C tuner when is present on the slot number 2
    - fixed a bug on channels scan
    - New EMUmanager v0.6
    - New MOUNTmanager v0.6
    - Improved stability when copying the FTP
    - Auto match menu skins for SD / HD
    - Added manual installation packages (BP-> Addons-> Install packages)
    - Added messages to the VFD for the mounting of CIFS and odmontowaniu
    - Auto restart if you are GS
    - Patch for the first boot configuration
    - Patch for icons DD
    - Added Media Center 0.9.2
    - Fixed the first start (fix black screen)
    - Added NETcaster (experymentalnie)
    - Added restart the GUI from the main menu
    - GoogleMaps updated to version dated 31-03-2009
    - Added support for files. Trp in MPlayer and MCenter
    - Updated to version mbox 0.4 BETA build 0023 2-nd
    9000 version here
    910 version here
    900 version here
    91 version here
  2. #32
    aftermath's Avatar
    Mar 2008
    Default Enigma2_0.3.3
    release 0.3.3:
    - fixed a bug on cuberevo-2000hd that caused no audio on all channels
    - fixed many bugs on channels scan (hope now it's ok on all sat)
    - first try to fix continue freezes bug after a real freeze happens
    - fixed some wrong autoresolution bug on many channels (like BBC, csat fr, etc)
    - new kernel version (2.6.17 p0041)
    - new implementation for CI cams (still needs to use upper slot for first tuner and lower slot for second tuner, this will be fixed soon),
    now CI cams should use less cpu time and should rallenty less the enigma2 execution.
    Cuberevo 9000 HD Flash
    Cuberevo 9000 HD USB
    Cuberevo 200 HDt Flash
    Cuberevo 200 HDt USB
    Cuberevo 250 HD ( 91HD ) Flash
    Cuberevo 250 HD ( 91HD ) USB
    Cuberevo 2000 HD Flash
    Cuberevo 2000 HD USB
    Cuberevo 9500 HD ( 7000 HD ) Flash
    Cuberevo 9500 HD ( 7000 HD ) USB
    Cuberevo Mini ( 900 HD ) Flash
    Cuberevo Mini ( 900 HD ) USB
    Cuberevo Mini2 ( 910 HD ) Flash
    Cuberevo Mini2 ( 910 HD ) USB
  3. #33
    Member grizzlyt's Avatar
    Oct 2008
    I hope you downloaded the right versions, they changed all the flash images yesterday because of a nasty bug.
    All flash versions are affected
    IP Box HD 9000 2xS2 tuner
    Dreambox 7025-SS
    Smart MX 28-IDTE IQ 2040
    Sammy 9500-Sammy 9400-Sammy 9000
    Triax 120 cm-Titanium 2 LNB's
  4. #34
    aftermath's Avatar
    Mar 2008
    yes these are all yesterday afternoons versions.
  5. #35
    Oct 2008
    Default Enigma2 Tideglo 0.3.3 mod PKT 3.4.1
    E2 PKT 3.4.1
    Modification based on the E2 Tideglo (Sifteam) rev 0.3.3
    This is only for the USB stick installation, it's like having a blue panel under Dreambox
    Changes in Tideglo in relation to version rev 0.3.1
    Release 0.3.3:
    * Fixed a bug on cuberevo-2000hd that caused no audio on all channels
    * Fixed many bugs on scan channels (hope it's ok now on all sat)
    * First try to fix bug continue freezes after a real freeze happens
    * Fixed some bug autoresolution wrong on many channels (like BBC, csat fr, etc)
    * New kernel version (2.6.17 p0041)
    * New implementation for CI cams (still needs to use upper slot for the tuner first and second lower slot for the tuner, this will be fixed soon),
    CI cams should now use less CPU time and should slow down less the execution of enigma2
    PolishKathiTeam changes in relation to version 3.4
    Release 3.4.1:
    * New EMUmanager v 0.7
    * Added mbox_CS - cardserver + acts as a client (tested with the card in C + phoenix per PL2303)
    * To download updated versions of softCAM
    * Fix configuration files softCAM - smooth cooperation newCS (Phoenix on PL2303) with Mbox, camd3 and Incubuscamd - tested on Cyfra + cards and TNK)
    * Minor changes script
    When you first start it is recommended you restart your tuner
    Regards Polish Team Kathi
    Dreambox 7025-SS
  6. #36
    aftermath's Avatar
    Mar 2008
    sorry i missed this post....
    Yes that is correct , it happens so fast you wont notice anything, this is normal..
  7. #37
    Mar 2009
    I have installed Enigma2 SifTeam 0.3.3 Flash image but i have tuning problem 4 satellite when i do tuning arabsat nilesat hotbird or astra when i config dieseq a,b,c,d only arabsat tuning is done remainin other satellite doesnt come what is problem plz help me! (250hd)
  8. #38
    Oct 2008
    Please read this excellent Tutorial from Aftermath, everything is explained there : http://www.digital-kaos.co.uk/forums...box9000-29363/
    Dreambox 7025-SS
  9. #39
    aftermath's Avatar
    Mar 2008
    Default Enigma2 Release 0.4.0 for 9000HD
    - fixed deep standby broken since 0.3.3 (do not forget to delete all wakeup timers from dgstation firmware, because if you forget it,
      then the box will restart automatically!)
    - added a Satellites configuration with all sat positions (if you think there's something missed you can still add yourself configuration files)
    - added a Terrestrial configuration to support almost all Europe providers (inserted general europe voice,
      obiously i can't add a provider for each one on the worl, so just update the file if you need a specific provider)
    - fixed some other channels scan bugs
    - fixed menu Network test on the "link connection" voice
    - fixed positioner menu crashes
    - MediaPlayer Bug with a gsod on NoneType error using subtitles
    - fixed rotor using diseqc
    - reboot of enigma2 now should works good
    - completed the kernel version p0041 adaption
    - improved a bit CI cams manager
    - fixed many memory bugs that caused the player to crash (let me know if you find more bugs on playing multimedia files)
    - ipkg support, as soon as sifteam will have a download for ipk files you will be able to download them from the browse plugin menu
    - added by default the file /var/etc/rcS_user.sh that is called on boot, so if you want to add any kind of command to be executed on start
      just put them in this file
    - patch for North American satellites (let me know if you find any kind of bugs)
    ATTENTION:
    if you are a NA user, do not forget to change in the "/etc/init.d/rcS" file this value:
    insmod $MODDIR/stmfb.ko display0=1280x720-32@50:12M:PAL:YUV:RGB;
    into:
    insmod $MODDIR/stmfb.ko display0=1280x720-32@60:12M:NTSC:YUV:RGB;
    This is needed to let you see the boot image and to have a full working display on TV.
    Ok that's all, i know there are some other bugs to be fixed, but i think there were a lot of improvement in this version and
    i'm working to some new drivers so i think before using the new drivers we should test all these improvements and then see if something could be better or not
    here
  10. #40
    aftermath's Avatar
    Mar 2008
    Default Enigma2 mod PKT 4.0 rev 0.4.0 ffor IPbox 9000
    Enigma2 mod PKT 4.0 in Tideglo E2 rev 0.4.0
    release 0.4.0:
    - fixed boot image that was not shown every time on every TV
    - revert back to python 2.5, now you can use all enigma2 plugins for dreambox receivers wich do not have sources available and wich uses only python files
    - fixed DHCP, now is working by network menu configuration
    - added the option to enable DHCP also with nfs-server to load enigma2 (just change the kernel loading bootargs)
    - fixed the overheading bug on date/time that caused to have always a wrong time/date
    - fixed tuxtxt crashes and outputs management
    - fixed the bug that causes Timezones outside of Europe not to work, always reverts back to GMT time. All times over 3+ GMT and under GMT did not work.
    - spdif audio output on ipbox91hd/cuberevo250hd
    - fixed subtitles on dreamtv-hd skin
    - fixed aspect ratio: Pan&Scan and Pillar box settings reversed
    - fixed menu selection options that were not selectable, like 8MHz bandwith selection, or many fec options
    - fixed skin HD
    - updated skin HD
    - enabled ntfs as module
    - patch for white subtitles (i don't know if this is usefull or not, but i thought it's better to have a
    white subtitle with black background, just more viewable)
    - fixed EPG button (now you can choose wich kind of epg list to view)
    ATTENTION:
    insmod $MODDIR/stmfb.ko display0=1280x720-32@50:12MAL:YUV:RGB;
    into:
    i'm working to some new drivers so i think before using the new drivers we should test all these improvements and then see if something could be better or not.
    Zmiany PKT
    - adaptation PKT mod to E2 Tideglo rev 0.4.0
    - minor fixes
    Pozdrawiamy Polish Kathi Team
    here
  11. #41
    aftermath's Avatar
    Mar 2008
    Default Enigma Images
    Abcom enigma1 beta for IP box 9000HD
    AB Enigma1HD_9xxx_110609beta
    This is Beta version of AB Enigma1HD for AB IPBox 9000HD/900HD/910HD and 91HD
    How to install:
    - unzip downloaded file to your PC
    - Copy file from your PC into USB flash memory and rename it into "usb_update.img"
    - IMPORTANT: Use "Safety remove USB device" function before disconnecting your USB flash memory from PC !
    - Turn off your receiver (Standby+OK on front panel) and connect USB memory to USB (host) connector on your receiver.
    - Press and hold Standby on front panel until "BOOTING" message appears on display,
    press Up button . "USB UPGRADE" message should appear on display of your receiver - software update performs automatically.
    - Wait until DONE message appears and restart your receiver.
    How to install E2 HD (USB stick version) via internet with E1 HD installed inside box (Multiboot function):
    - connect USB flash memory to receiver and formatt it to ext3
    - go to Menu - Setup - System settings - Harddisc setup - line "connected"and make sure if USB is mounted to /hdd or /mnt/sda (if you don?t have installed HDD) or to /mnt/sdb (if you have installed HDD)!!!
    - press blue button and go to "tarx", press OK, and choose "Download Addon". You will see "Enigma2.sda" and "Enigma2.sdb" files for each model of HD boxes.
    "Enigma2.sda" - choose only when you don?t have installed HDD
    "Enigma2.sdb"- choose only when you have installed HDD
    - after choosing correct file, download will start and after that confirmation window will appear - press OK on "yes"
    - when you will see window with "OK", you have successfully installed E2 HD on USB
    - if you want run E2 HD just turn box off (Standby+OK on front panel),that press standby button and press and hold number 2 or 3 (it depends of installed HDD)
    number 1 - booting from internal flash
    number 2 - booting from sda
    number 3 - booting from sdb
    number 4 - booting from nfs
    number9 - booting from set up enviroment 192.168.1.25 ipaddr,
    192.168.1.102 server ip, nfsroot
    /home/ipbox/rootfs
    This can be helpfull:
    - IMPORTANT: By manual searching of channels ever press "retune" after inserting all parameters.
    This behavior differs from original E1, so don't forget about it when you need to do manual scan
    - In Expert setup you can find "User reset" - this returns box to first setup with basic setting for 4 satellites
    - In menu "Common Interface" you can find this: "can handle two services" - when you marked it to on, it is possible one scrambled channel record and one scrambled channel from same TP watch.
    Note: this function must be also supported by CAM module!(e.g.Cryptoworks from Mascom supports this)
    - If use 720p or 1080i mode with teletext, after teletext switch on, press Menu button and activate "true type fonts" item.
    Please note that this is E1 HD, so in IP9000HD is supported only first tuner.
    Known issues:
    - DVB-C tuners not supported
    - internal card readers don?t work (external USB card readers work)
    - works upper CI slot only, after inserting CAM module you have to restart it in menu of box. After every restarting of box you have to put out CAM from box and put in to box and reset CAM in menu of box.
    - DVB and TXT subtitles are not working
    - problem with formatting some 3,5" HDD?s
    - some bugs by playback recordings from HDD
    - it is not possible timer recording from EPG
    - SD menu graphic supported only
    - installed games don?t work in 720p and 1080i mode. (work in 576i and 576p mode)
    - signal indicators don?t work
    - in some situations box doesn?t present any channels, need reinsert CAM and reset CAM in Common Interface menu
    here
  12. #42
    aftermath's Avatar
    Mar 2008
    Default Enigma1 for HD boxes, 15-06-09 release
    changes:
    - fixed videoformat settings
    - fixed S/PDIF, HDMI volume control
    - add possibility change swap to other media (HDD, USB)
    - add driver for card readers
    - update Kernel 2.6.17.14 stm22 041 version with Open VPN support
    RapidShare: Easy Filehosting
  13. #43
    aftermath's Avatar
    Mar 2008
    Default Tideglo E2 AAF RISING SUN - IPBOX 9000 Beta
    EME for the boot image
    xup12 for the radio image
    matze70 for the settings.
    Image Info
    Tideglo 0.3.3 e2
    Thanks to Team Ducktales and Tideglo basis for the great image and this image all the permits and have tested.
    AAF extensions:
    AAF + Rising Sun boot image
    + AAF Radio picture
    + HD-Skin Ice Metallic
    + HD-Skin Wine Metallic
    + Nblue.BlackBoxSD
    + Addon Manager 1.68
    + New settings by Matze
    Core is the AAF Panel (Custom Settings menu with enlarged functions and [red button])
    + Automount for USB and registered CIFS / NFS shares
    + BlueKey Action (Blue button itself suitably for desire plugin)
    + Optional NTFS support
    Optional + Samba Server
    + USB2Serial Driver (optionally activated - for external card reader)
    + VFD display settings (currently first time on / off)
    + Softcampanel (to manage Softcams)
    + Addon Manager (install and uninstall of additional functions / programs)
    + UpnpFS Support
    + Internal Card Reader Support
    Control + NewCS
    NewCS Control found in AAFpanel - AAF Extensions!
    On E2 ipbox AAF Image work with:
    megasat4000 (ipbox AAF-Image)
    Sofa tester
    GOst4711
    Black_64
    Bauernbub
    max10
    xup12
    grizzlyt
    spock1111
    Menne.0201
    Prof-clueless
    Have fun testing
    Your AAF-TDT Tideglo Tea
    here
  14. #44
    aftermath's Avatar
    Mar 2008
    Default e2_050_pkt05a_ddtk40
    e2_050_pkt05a_ddtk40 for USB stick
    fix_11.07.2009
    CrossEPG version 0.3.0rc2
    incubusCamd to vers. 0.88
    plugins Advanced FileBrowser
    plugins FileBrowser
  15. #45
    Oct 2008
    Default IP-Box-AAF-SummerDream
    This is now the second release of AAF
    Release 0.5.0:
    - fixed a bug on rebooting the system
    - better CI cams handling
    - support for upper and lower CI slots on the current live tuner, no more needs to put the cam only on the upper one
    - added new dvdplayer
    - support for timeshift
    - fixed alpha blending colour on images
    - updated e2 cvs to 30/05/2009
    - fixed fstab auto mounting for hdd
    - vsftpd log on file disabled by default
    - fixed a bit keymap for 250hd/200hd, audio subtitles now is mapped
    - added autoload of epg (using myepg now the file will be loaded automatically at enigma2 restarts)
    - some fixes on mediaplayer for some multimedia files
    - many fixes all around for better stability, now i think most part of drivers are done
    - updated arabic language
    AAF:
    + AAF-Panel V4.1
    + Softcam-Panel V0.21
    + Addon-Manager V1.73
    + MediaCenter
    + VFD-Standby V0.1
    + Automount
    + Cifs,Samba
    + Cardreader Unterst?tzung
    + NewCS Control V0.2
    + Permanent Clock
    + SetstartChannel
    + Network Browser
    and lots more....
    Thanks go to Tideglo-TDT for the superb basic image and to all that have contributed and tested it.
    Image builder:
    megasat4000, GOst4711, Black_64, Sofatester
    Beta tester:
    xup12, spock1111, grizzlyt, zeroone, trodonaldo, Menne.0201, Prof-Ratlos
    We wish you lots of fun testing, your AAF - TDT - Tideglo TEAM
    IP-BOX 91
    File-Upload.net - IP-BOX-AAF-SummerDream-91HD-USB.tar.gz
    IP-BOX 900,910,9000
    File-Upload.net - IP-Box-AAF-SummerDream-USB.tar.gz
    Dreambox 7025-SS
