EPG on HDD or USB ?
    Apr 2013
    Default EPG on HDD or USB ?
    As title guys, I'm running a solo2 clone with VIX 3.0. Everything was set up by the seller with Softcams, Boutique and cross EPG ready installed. It has a 500GB HDD installed, am I better inserting a USB stick in the back to write EPG to or is it safe to leave as it is ?
    Sep 2008
    it used to be setup to usb but reading elsewhere on originals now been told internal hdd,if working dont mess is the saying.
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    I've always kept epg on the Hdd never had any problems you can always clear any epg data on Hdd as well. As above if it aint broke don't fix it.
    digicon's Avatar
    Either does not really matter as the EPG is loaded into the Ram and stays there everytime you switch the receiver on until you switch it Off/Standby.
    Picons should really go onto a USB as they are accessed everytime you switch channel
    Jun 2018
    Virgin Islands
    use a rear usb stick and point crossepg at it for saving and loading your epg not the internal flash or hdd
    DK Veteran lincsat's Avatar
    Jun 2008
    It's perfectly fine to use the HDD for EPG and Picons, some people even use the HDD for live pause/permanent timeshift which does give heavy use on the HDD.
