Results 1 to 15 of 24
    Hanukkah's Avatar
    Default 2014 Toyota Fortuner Immo Help...
    Engine ECU is 89661-OKXXX
    Is there an immo off for this?
    Cannot locate immobox with 89780 part number behind or below dashboard or behind glove compartment.
    Thanks in advance...
    iamfooser's Avatar
    Sep 2012
    Key system or proximity?
    Hanukkah's Avatar
    Quote Originally Posted by iamfooser View Post
    Hi still using Toy43 3B Remote key... "G" stamped on key blade mate.
    iamfooser's Avatar
    Sep 2012
    Did you try looking for it behind blower? Not possible to do immo off as I know.
    Hanukkah's Avatar
    Will see if there is immobox behind blower... Thanks
    Hanukkah's Avatar
    Found immobilizer after removing dashboard. Behind center blower louver (a few cm below windshield) mounted to firewall. Cannot miss it as there is a wire harness...
    Immo part number is 89780-71030
    Anyone can help reset this so I can add the 2 oem keys. Thanks.
    Last edited by Hanukkah; 17th April, 2014 at 01:18 PM. Reason: added few details...
  7. The Following User Says Thank You to Hanukkah For This Useful Post:
    gordonjairo (18th August, 2014)
    iamfooser's Avatar
    Sep 2012
    Great. Can you please kindly take a pic of the location?
    As for the immo, we will have to wait for our expert. I think you will need to post key data.
    siyadk's Avatar
    Dec 2012
    ya a picture will be great and the part number
  10. #9
    gwee's Avatar
    Dec 2012
    unknown
    ready to add key
  11. The Following 2 Users Say Thank You to gwee For This Useful Post:
    Hanukkah (17th April, 2014), nomis (19th April, 2014)
  12. #10
    iamfooser's Avatar
    Sep 2012
    Here comes our expert. Hahaha
  13. #11
    Hanukkah's Avatar
    Thanks gwee...
    BTW, what is procedure for adding key?
  14. #12
    gwee's Avatar
    Dec 2012
    unknown
    you will need key with pg1 - 36 or 56.
    if u are adding 2 keys, i think first u have to insert first key, wait for few seconds then pull out,
    insert the second key and turn ON OFF 5 times quickly to close the learning mode.
  15. The Following User Says Thank You to gwee For This Useful Post:
  16. #13
    iamfooser's Avatar
    Sep 2012
    If it is like usual, the immo light should stay on when you plug in the immo box. As you insert the key, light will blink once and continue to stay on. Insert another and it should blink again. After closing the learning procedure, light will blink like normal. Not sure if it is the same for this car.
  17. The Following User Says Thank You to iamfooser For This Useful Post:
  18. #14
    Hanukkah's Avatar
    Many thanks gwee and iamfooser...
    Will do this tom and report how it goes.
    Thank you brothers =)
  19. #15
    achaccha's Avatar
    Nov 2010
    Try an report. please disconnect the immobilizer or cut communication to the ecu immo
    pass: mp
  20. The Following 2 Users Say Thank You to achaccha For This Useful Post:
    Hanukkah (19th April, 2014), rtbdiagnostic (8th January, 2021)
