Enigma 1 + 2 Tools / Addons / Tuts - Page 2
Results 16 to 30 of 33
  1. #16
    Mar 2009
    Quote Originally Posted by aftermath View Post
    dont forget if you want to edit files on USB stick if you are booting from flash image. files are on mnt/usb/usb0
    but when booted from E2 on usb stick files will be in normal status var/keys e.t.c
    Gotcha
    All working anyway with your image now. This is one easy processs thanks to the likes of yourself.
    Thanks for your help
  2. #17
    Jan 2009
    Thanks for that grizzlyt +Aftermath.
    I was having trouble downloading from rapid share (Always do for some reason) so I got someone else to download it for me.
    I've uploaded it here for anyone else who hates the silly delay and daily download limit on rapidshare.
    http://www.filebam.com/download/107768-b99c16/E2_0.4.2_Ghost.rar
  3. #18
    aftermath's Avatar
    Mar 2008
    here is a backup of ghost E2 0.4.2 without my settings, so install as normal using Ghost and go through the setup stage, then add a satellites.xml and your incubuscamd.conf.
    make your own satellites.xml from here
    RapidShare: Easy Filehosting
  4. #19
    Newbie Peter36's Avatar
    Jun 2009
    Default Internal Cardreader Driver for e2 images
    INSTALLATION
    Copy contents of archive to box.
    The CardPanel Plugin for e2 takes care of loading the driver at e2 startup.
    It also starts newcs 1.66_rc1.
    newcs.xml is located in /var/keys, a default config is provided, adapt it to your needs.
    MAKE SURE ALL FILES ARE EXECUTABLE!
    Restart e2 to load the driver and newcs.
    KNOWN BUGS
    - Removal or insertion of a card while the driver is loaded freezes the box, so don't even try it
    Have fun,
  5. #20
    Jun 2009
    Default Addon pre e1 HD Put
    Addon pre e1 HD
    Put this file in /tmp/ and after from panel you can install mbox and newcs
  6. #21
    Member grizzlyt's Avatar
    Oct 2008
    If you want to see your partitions under Windows you can use this nifty tool :
    Ext2IFS
    It provides Windows NT4.0/2000/XP/2003/Vista/2008 with full access to Linux Ext2 volumes (read access and write access). This may be useful if you have installed both Windows and Linux as a dual boot environment on your computer.
    The "Ext2 Installable File System for Windows" software is freeware.
    IP Box HD 9000 2xS2 tuner
    Dreambox 7025-SS
    Smart MX 28-IDTE IQ 2040
    Sammy 9500-Sammy 9400-Sammy 9000
    Triax 120 cm-Titanium 2 LNB's
  7. #22
    Jun 2009
    Default Enigma 1 + 2 Tools / Addons
    e1 HD addons
    emus:
    mbox
    newcs
    keys-updater
    games:
    pacman
    snack
    tetris
    plugs:
    rss feeds
    weather-sky
    setting:
    setting-rotor
  8. #23
    aftermath's Avatar
    Mar 2008
    Default Cardreader driver for enigma2 images
    INSTALLATION
    KNOWN BUGS
  9. #24
    aftermath's Avatar
    Mar 2008
    Default PCEditor 1.2.53.2 - 19.10.2009
  10. #25
    aftermath's Avatar
    Mar 2008
    Default PCEditor 1.2.54
    Changelog PCEditor 1.2.54, 21.10.2009:
    - Fixed: Upload channel database
    - New: Create database R11014
    - New: Invert selected channels
    RapidShare: 1-CLICK Web hosting - Easy Filehosting
  11. #26
    southwest uk
    Default enigma 2
    As a total beginer (thick) I would like to know what enigma2 actually does when loaded on the cube revo, I know this is real basics but my brain is being overloaded with so many threads/posts but none actually start at the begining
  12. #27
    V.I.P. Member westkill's Avatar
    May 2008
    Quote Originally Posted by roebuck View Post
    enigma2
    there different firmwares that can be put on the box which is a linux operating system the same as a pc which operates all the menus,,scanning ,channel lists features etc in the box
    so you can use an ftp programme "file transfer protacol" to access change files and so on
    dm800-s=1.1 m triax motorised dish=titanium twin lnb
    DIGITAL KAOS BEST SITE ON THE NET
    please use the thanks button if someone has helped
  13. #28
    Bacau
    Hello! yesterday i buy an IPBOX 910 Hd and my problem is: how can install image and emu for view digi tv? I m from romania and maybe someone want halp me
  14. #29
    Apr 2009
    Hallo grislyt,
    some time ago i used a ghost image with my IPbox9000 and it worked good. There were memoryproblems with that imago so i returned to NLB.
    I cannot find any new ghost images Can you help?
  15. #30
    May 2009
    Middle of everywhare
    goofy17
    I know its been some time for you to get a reply..
    I can make a ghost image of any one of the USB version for you....
    If you would like me to do this let me know...
