Depends what image version ur using if it works or not. I found it using tspanel in the plugins section
im using openvix..but as i have azgemma box (not supported by openvix) plugin downloads dont work.. ive been using the clock plugin for about a year..so works fine with vix and gemma... but i updated to latest vix and now i cant download it anymore.... i only have 4 plugins that i use...ccam / mgcamd / clock / red hd skin / only the clock missing
as you already noted OpenVix put the brakes on the loophole to the plugin server downloads your only option is to find the plugin as a .ipk installer or change your image
If you still want to use an unsupported Openvix, here's a cheeky little cheat you can do if your having trouble google searching for the .ipk file, all your doing is pinching the latest .ipk file off the openatv feeds, good for future updates
1. Download a base Openatv image from the zgemma.tv website
2. Install and complete the config screen
3. Telnet to your Zgemma using your PC by opening a command prompt(admin) and
i. Type 'Telnet' and the IP address of your zgemma and press return
ii. Type 'root' and press return
iii. Type 'opkg download enigma2-plugin-extensions-permanentvfdclock' this will download the latest .ipk file to your Zgemma
iv. FTP to /var/volatile/cache/opkg and drg the .ipk file to your PC's desktop
4. Flash Openvix and FTP the .ipk file to your Zgemma and install via the local extensions menu
digicon (16th October, 2016)
to save the hassle
happy_highlander (27th June, 2017), martin035 (16th October, 2016)
