I cleared for you in other thread and you said OK, what's up mate ?
Attachment 442149 plaese help clear crash thank you (2012 hyundai genesis 95640) 95910-2M200
Best regards.
Dragon
Hello! I have 2012 elantra SRS module
95910-3X000,EEPROM 25128.Mobis Continental.2012 elantra 95910-3x000 25128 crash.zip2012 elantra 95910-3X000 95128 CLEARED.zip When I cleared file,I still have crash and code B1724 (driver impact sensor error) Found no problem with sensor and wiring.Tried other good file (95910-3X010),-internal module fault and crash.I suspect bad eeprom reading.Can you help me?Thanks.
Please help. Ineed clear crash this modul honda acord 2004. SRS 77960-SEG-G812-M1 EEP.95320
http://www.digital-kaos.co.uk/forums...960-seg-812-m1
Like to know what is the better programmer to use for W205 SPC560P50L3 micro controller chip. Have you maybe got the connection pin diagram to connect JTAG to SPC560P50L3. Do you need external 12V or no external 12V. Have you got a clear crash file for a W205 C180 2015 RH model please. Airbag model A205 900 86 18 Appreciate your effort. Thanks for your help.
Gouepenny
Hello, I need orginal dump with out crash of seat Ibiza 2015 , with this nomber: 6C0959655E_0285012568_ IC 95640 .
Hi mate, you can clear crash for a Hyundai H1 95910-4H500 Ver.2.0
Thanks in advance!
Please help clear crash Peugeot 208 028012632-9810363180 eeprom 95320
peugeot 208.rar
Hello
here is your dump cleared
good luck and don't forget to post result
IF I HELP Don`t forget to use Thanks button and reputation
I give negative reputation for people who even a THANKS not give for received helps!!!
New Users Don't PM me for radio codes or similar, you will not get any answer...
BR foks025
sinisa123 (5th August, 2017)
I have here:
98820zx10a
2010 Altima.
has both 93c76 and 93c66 inside.
which one need to be read to clear crash ?
some say 93c76 others say 93c66, which one is correct ??
Read 93c66 eeprom .....
Best regards.
Dragon
vladoford1 (5th October, 2017)
Helllo DK.please help me clear crash shevrolet 15860057. 908AS60A
THANKS+REP
dear please clear crash
