Results 1 to 1 of 1
    Apr 2014
    Default Disapearing settings from cluster panel/BSI Citroen C5 (X7) 2010 2.0 HDI 163km
    My problem is complex but probably connected to one module, main looks like when I switch off car and wait until asleep, all settings, board computer calculations back to previous values, affected are things:
    1. Board computer counts and shows milage, avg speed and fuel consumption from reset when car is running till car asleep. After I back to car I have some previous values like distance 9999km, on second card, on first cart, last time 15km distance from start has been stored and now this is default value.
    2. From menu in cluster panel (under left roller) you can set a few things like "follow me home" etc., everything is selectable but after sleep back to previous values.
    3. Service Maintenance reset can be done but after sleep shows back "Inspection exeeded by 99999km" or something similar.
    4. Suspension Sport button can be activated and deactivated when car is running but button state is not stored after ignition off.
    5. ODO meter is always shows 1239.1km when I start after car sleep no mather how many times I reset it.
    6. Last time remotes controls (original from cars keys) stop working when car is in sleep mode but working perfectly after ignition off till car asleep.
    DTC from BSI:
    FA4A - no description, can be reset always back after sleep,
    F5FF - unexpected reset - can be reset apears sporadically
