You cannot unregister the CID, if you have radio with different code. Only matched sets can be unpaired with Opcom/Tech2
CD30 is unregistred!
security wait time is NOT running
Marry radio with code 9499 to CID. After that unregister radio again. Both will be unregistered then.
gogo_yanev (11th May, 2014)
as above, should have caught that earlier!....
nice catch exe123
I think your CD30 is not unregistered proper, write back original dump and try to unregister yourself using op-com or tech2 and CD30 pin code 2115, then marry it to CID...
...did you try pin code 9949 in other units?
That CD30 dump is not unregistered correct.
try cid display code
audiopoint (13th May, 2014)
Here are the facts:
CID code 9949 is 100% correct.
CD30 unregistered dump from nelutzul40 is NOT unregistered!
Matched set only can be unregistered via OpCom/Tech2!!!
If CID and radio have different code, it will fail.
audiopoint (13th May, 2014), ilukasz (3rd July, 2019), mcd76 (13th May, 2014)
the problem is solved
you were right for cid display code ... 9499 is good code
i used this unreg dump http://www.digital-kaos.co.uk/forums...gister-398457/
and everything is ok
i married cid and cd30 whit op-com
Good to hear that
Btw. it is a GID (Graphic Info Display) CID is with color
please code for another one gid display
9163 is it correct code?
gid 93C66 8 bit.rar
gogo_yanev (14th May, 2014)
