    ruffles1986's Avatar
    Sep 2011
    In the Garage
    Default Problem renault F8Q Pump Lucas
    I have problem with Renault Kangoo 1.9 F8Q from 1999, the car start 1 second and stop.
    The immo light go off, if i turn on without tranponder then blinking. With Autocom i see Start Autorithation OK with transponder, i do some test and i discard immo fault.
    I have Stored DF066 Fuel flow actuator position; incorrect position, and DF054 Pump memory circuit fault.
    Then i dissasambled OSM sensor, remove blue glue and read eeprom 93c46 for do recalibration, after do recalibration same problem and same DTCs.
    I attached ori dump and recalibration dump.
    Any idea?
    Sep 2011
    In the Garage
    Nobody had similar problem?
    Jun 2013
    corrupt dump
    Jun 2013
    reno first 4 to 8 lines and dump immo box next 4 lines will be the same
    Sep 2011
    In the Garage
    Then the dump from OSM sensor have inmobilizer data? Or the dump simplily is corrupt and need other correct dump?
    Enviado desde mi GT-I8260 mediante Tapatalk
    Feb 2016
    Hey have a Renault Kangoo in 2002 with the same error as you. How did you solve your error?
