Page 1 of 3 123 LastLast
Results 1 to 15 of 32
    i_shot_the_sheriff's Avatar
    Nov 2008
    Default Opel Corsa D Ecu blowing fuse
    Hey mates,
    I got an Opel Corsa D Z13DTJ 2007 model and ecu MJD 6O3.S3 55568383. This car came to me because it's blowing the fuse for main relay all the time (10amps) !
    The DTC shows P1625 and if you disconnect the main relay fuse still goes bad,,,,, i've tried everything ,,, at last i disconnected the ecu and fuse is ok with ignition on!!
    I have opened the ecu but there is no visible burnt component or something
    Has anyone seen this before? is there a way to repair the ecu?
    I have read somewhere that the chip L9131 is controlling the power output and input of the ecu,,, maybe it's shorted?
    Cheers
    Meat-Head's Avatar
    Ok new fuse unplug ecu shirt 87 to 30 on relay stand back ...
    then hen repeat experiment (iShit failure) unplug relay ecu, stand back
    what about radio Milagros (iShit failure) locking bcm ses (iShit failure ) do they stay low of high volts in tech2?
    genius76's Avatar
    Dec 2012
    Lowestoft
    Hm have long time ago sharan 1.9 tdi not pd
    Gui draive with blowing fuse until car stops at all
    Dead fuel pump regulator, shorted oleays ecu and blowed fuse every 10 miles
    Ford fiesta 1.4tdci luse wires from crankshaft sensor sorted to driveshaft blowing fuses ecu until car not start at all
    tray disconect some sensors first maibe here something shorting
    I can help you but only if you want me to help you
    All the questions should start from what car, what year, what engine is what fuel. What are the symptoms of the problem. Only then is what you know, what fault code, live data, what you have done.
    racin-snake's Avatar
    Jun 2009
    what fuse ? give fuse no and details of components it covers please also maybe look at wiring diagram and see what fuse covers for yourself ?
    Today is the Tomorrow you worried about yesterday ......Was it worth it ?
    Top Poster saka112's Avatar
    Sep 2011
    try to remove fuel pressure and see what will happend
    Nov 2008
    I have tried unplugging sensors but its still the same! Only difference is when unplugging ecu!
    Today ive tried another ecu from a multijet (totally different nunbers) and the fuse is ok!
    Fuse is 10 amps in the front fusebox and as far as I remember its in the 20th position (not really sure as car is kinda far from me and I come and go)
    levisdj's Avatar
    EcuLand
    Did you sort this meanwhile ? I have a similar issue... will update in the afternoon
    So I opened the ECU, it doens't have visible water damage... alltough someone else has resoldered the big capacitors... in my case it kept blowing the F33 fuse 10A.... I replaced it with a 15A fuse ... that isn's blowing anymore, but still no crack and DTC P1625-02 Main relay low voltage...!Any suggestion is welcomed
    Meat-Head's Avatar
    Sounds like both cars voltage regulator, work out which pin is incoming then first chip it hits see if gets hot and type number off chip into google with datasheet
  9. The Following User Says Thank You to Meat-Head For This Useful Post:
    levisdj (12th February, 2018)
  10. #9
    Quote Originally Posted by levisdj View Post
    If not blow fuse,check inside again maybe some line in circuit
  11. The Following User Says Thank You to synkrotronic For This Useful Post:
  12. #10
    Jun 2009
    I have had the same ecu problem after repair for water ingress , never got round to repair but it was same codes same symptoms used ecu ficed fault
  13. The Following User Says Thank You to racin-snake For This Useful Post:
  14. #11
    levisdj's Avatar
    EcuLand
    Yeah, today I will get back to the car and will update this thread, thank you all for your time
  15. #12
    levisdj's Avatar
    EcuLand
    Ok, so updating this issue... the 15A got burnt eventually ... so what I did today was to remove the rail sensor plug(see photo) upgrade to 20A fuse.... (see photo) and the Main relay error was gone but I got a new one (see photo) ... after 5 minutes on ignition I started to smell burnt... and after seeing what's about.... all those parts in the red circle were burning hot... does that mean that the ecu is gone ? or should I unplug all sensors first and see what changes ? Me, never seen a Capacitor dtc before...thanks
  16. #13
    levisdj's Avatar
    EcuLand
    Quote Originally Posted by JoK View Post
    Its got a 10amp fuse in for a reason, so why put a 20amp one in it's place
    Just short fuse out with nail, see how hot it gets then
    JoK
    I don't know wether to laugh or to cry for this helping answer ...!
  17. #14
    test every transistor in red circle and all the other ones
    maybe u got a transistor that's internally shorted???
  18. The Following User Says Thank You to fes_786 For This Useful Post:
    levisdj (13th February, 2018)
  19. #15
    levisdj's Avatar
    EcuLand
    I got a spare ecu coming in tomorrow... will swap eeprom data from one to another and update how that goes!Thanks guys!
