Try this files.
Try this files.
galaxy0634 (10th May, 2019)
hello. can someone make immo off opel vivaro 2,5 tdi edc16 ?
buy an emulator, it will contain instructions for installing and repairing eeprom
Opel vivaro 2.0
Please virgin file
Please virgin eeprom Opel Movano 2.5 CDTI read by KTAG
Waldi, is it possible?
0281014648
No army may enter that land
That is protected by polish hand
Unless you are 40 to 1
Your force will soon be undone
Hi I need Virgin File Eeprom VIVARO EDC16C36 I have fault P0089 Thank You
Hi guys, can u please help me with ECU dump, it is from renault master
VIN: VF1FDC1HH70644318
Build dec/2007
Ecu had P0606 code logged and all the data in EEPROM is missing, injector coding and VIN etc.
can u please rebuild this eeprom file or supply a virgnise file.
if virginse then what is involved in programming it? i know injector coding and vin coding but do i need immobiliser programming as well,
Master.rar
Try this file.
Hello !
I have a ECU EDC16C36 of Renault Master 2.5 with DTC P062F - Eprom fail memory
Waldi can you make a virgin file for me?
ECU 0 281 013 364
[QUOTE = dell66; 2861544] Adjunto está su archivo en blanco, configurado con el clip Renault [/ QUOTE]
password please thanks
Hello friend. I have problem with Nissan Interstar 2.5dci 120ps. I have two P0611 pressent and no error P062f for eeprom. I cant code injectors car is stuck at 1500rpm. Tried to code injectors with Bosch and Launch X431 and didnt succed I have read ori eeprom, can someone repair or make virgin so that i can code injectors and solve problem? Thanks in advance! In attachment ill leave ori eeprom
anyone? thanks
