Renault Master 2.5 DCi EDC16c36 virgin - Page 3
Page 3 of 25 FirstFirst 1234567813 ... LastLast
Results 31 to 45 of 366
  1. #31
    Jan 2017
    Hi Friends,
    I have a ECU 281 013 364 and the 95320 CI is burned.
    What file I can use in this case?
    Its a Renault Master.
  2. #32
    italia roma
    helo.
    pls. help me passwords for file master orig 95320 blank file
    thank you
  3. #33
    Please virgin my dump 0281013364 oder share anz good virgin dump
    Old ecu is dead
    Best Regards
    Darek
  4. #34
    Hi waldi1979, could you help me with this dump? thanks in advance
  5. #35
    Quote Originally Posted by waldi1979 View Post
    Try this files.
    Hello waldi
    I have corrupt eprom dump. Ecu - Renault Master EDC16C36 3.1 - 0281013363
    I Put FFFF - 3E - 7FF , But problem coding Inyector.
    Could you send me a good file to test
    Could you send me a file to prove
  6. #36
    waldi1979's Avatar
    Dec 2010
    Quote Originally Posted by bahlawi View Post
    Here you are,
  7. The Following User Says Thank You to waldi1979 For This Useful Post:
    majster10 (29th April, 2020)
  8. #37
    waldi1979's Avatar
    Dec 2010
    Quote Originally Posted by valty View Post
    Hello waldi
    Try this file.
  9. The Following 3 Users Say Thank You to waldi1979 For This Useful Post:
    kader30 (13th June, 2017), kania (12th June, 2019), valty (2nd May, 2017)
  10. #38
    Hello waldi1979
    File work 1000%%% - coding vin, coding inyector and all work fine
    Very thanks.
  11. #39
    DK Veteran dollarbill's Avatar
    france,paris
    hi
    please waldi1979 i need help for virgin this ecu 0281013364 thanks you very much in advance
    if i help don't forget a thanks
  12. #40
    in Spain
    Default df107 problem
    Hi, Waldi1979!, I also have problem with this ecu 0281013364 (DF107). Please make my dump virgin?. Thanks in advance.e2prom.rar
  13. #41
    Dec 2016
    i have broken eeprom file, can someone help to fix it?
    not possible to write inj. codes.
    renault master 2.5
    ecu: 0281013018
    thank You
  14. #42
    Bllinda's Avatar
    Baltic
    I think we will be able to transfer data to your file
    vin,KMx7,inj ....
    pin:xx xx A8 ....
    Novēlu jums jauku dienu
    today
    A topic that interests me
  15. #43
    Default Renault Master Virginize 95320
    hi could anybody make this virgin please
    had to replace a total corrupt ecu
    attached eep file read by ktag
    master ori.zip
  16. #44
    waldi1979's Avatar
    Dec 2010
    Here you are.
  17. The Following User Says Thank You to waldi1979 For This Useful Post:
    feikuk (22nd June, 2017)
  18. #45
    Mar 2015
    Default need virgin 0 281 013 364
    hello, need too virgin for master. Thank?s for help
