Results 1 to 3 of 3
    Top Poster + sony007's Avatar
    Sep 2011
    Default Whats the best way to stream one DM to multiple TV'S around the home?
    With the sky hd+ boxes you can use coax cable to connect from the 2 RF out on the back of the box to the TV's that for me was great as the picture quality was decent.
    With a wireless sender receiver connection there's to much interference and a weak signal if the area is to big and obstacle in between.
    I searched for scart to rf convertor on Ebay and found a few items that may be the job but they only have one RF and I would require 2 RF out.
    digicon's Avatar
    I can only suggest that you use an RF modulator that generally come with 1 scart input 1 CVBS Phono input Aerial in connection and the all important RF out connection to supply your other TV, as you want 2 then you would have to purchase a 2 way splitter to feed the 2 x TV's out from the 1 single RF output on the Modulator.
    If your looking for Magic Eye control then you would need the Triax Tri-Link same thing an RF modulator but includes Magic Eye capability
    Sep 2011
    I've just picked up a Triax Tri-Link Kit. Thanks for your advice Digicon it iwas much appreciated.
