Results 1 to 12 of 12
    MOHCIN2's Avatar
    Feb 2013
    IN GOD'S EARTH
    Default need diagram to read Mercedes C - 0 285 001 373 - Bosch 001 820 97 26 airbag unit
    hi i need diagram to read Mercedes C - 0 285 001 373 - Bosch 001 820 97 26 THANKS with hc12 maskset 0J38M or the procedure to make it virgine this airbag unit by using the developer mode in star by the way i use xprog and upa programmer
    autodigitec's Avatar
    Aug 2011
    PT
    Just incase someone else searches for this, pretty easy to read with carprog (50$ clone works too, no need to struggle with xprog/upa)
    In my case:
    02850012373
    001 820 97 26 [00]
    Q9
    0J38M - HC12
    READ+WRITE 100%
    Working on something to release next month for free for all dk users :>
  3. The Following 36 Users Say Thank You to autodigitec For This Useful Post:
    alex2019 (5th December, 2019), ali kaptan (21st July, 2022), burnster (20th May, 2021), BusCan (4th March, 2019), byyoyo (22nd March, 2019), capi (10th March, 2021), danielif (7th November, 2023), djmusic (9th March, 2022), duco (30th March, 2016), elitricista (16th May, 2018), ernesto1670 (21st October, 2015), estrelles (6th February, 2018), FxShaw (5th February, 2018), Ginocar (3rd February, 2021), Hayssam1 (13th February, 2023), Johann (23rd January, 2017), kinketotua (3rd October, 2017), klonone (25th August, 2015), kvalentino (25th February, 2022), motocarlos (15th March, 2020), nasscristhian (17th August, 2022), nelsoncaseiro (19th March, 2022), neo6120 (19th December, 2023), ntom (28th February, 2016), parrot1964 (12th October, 2022), petan (16th April, 2024), songokus (4th April, 2017), sonho1999 (22nd November, 2019), tarasad (4th March, 2020), tellfaia (2nd June, 2023), Traser (28th June, 2023), tuberider (8th March, 2021), voldoverse (11th April, 2023), whim (21st January, 2020), zuzuss (1st August, 2015)
    Oct 2016
    If I replace the Lockset of the car the SRS light keeps on all the time. I have the SRS module of the original Lockset but I want to read files and save them for future. Is it in same location as the crash data?
  5. The Following User Says Thank You to Johann For This Useful Post:
  6. #4
    Jan 2018
    Hello please I need your help, I can not read the mcu hc12.A 285 001 373 with carprog Can you explain how to connect the pins GND, BKGD, RESET, RED + 5v, VIOLET + 10? I have soldier like in the picture, and I can not read I do not know what to do with pin 1 of the eprom.
    pin 1 = vss = Red + 5v?
    I have connected it as in the picture and it still does not work in the manual of carprog the switchboard has a different connection attached the imagecar-prog-motorola-hc12-programmer-manual-4-638.jpg
    FxShaw's Avatar
    Nov 2013
    Outta This World
    Dont need to use the violet wire.. gray,brown,blue & red wire only the guy made the color exact to match cp colors. connect exactly as he did and try reading.
    🔥Wacka Wacka 🔥
  8. The Following User Says Thank You to FxShaw For This Useful Post:
  9. #6
    Jan 2018
    All solved the adapter had a small short circuit. Thank you very much everything has been useful.
  10. The Following User Says Thank You to estrelles For This Useful Post:
  11. #7
    Mar 2017
    Hi Sir, do you have some pinout for Xprog machine. I do not have carprog.
  12. #8
    hello please help me to remove crash airbag w203 Bosch 0285001373 thank you very much
  13. #9
    whim's Avatar
    Feb 2011
    plesea only english
  14. #10
    [QUOTE = caprice; 3774226] plesea seulement anglais [/ QUOTE]
    sorry but smartphone translate english to french auto
  15. #11
    BRASIL / SUL
    Default Clear
    here it is, clean file, if i helped you leave a positive, thanks.
  16. #12
    Jan 2021
    Default Class C, airbag clearing 0 285 001 373
    need to clear airbag crash, mercedes c210 bosch 0 285 001 373
    Thanks,
    David
