Page 1 of 9 123456 ... LastLast
Results 1 to 15 of 122
    dimitar's Avatar
    Default OPCOM 120309a for china clone
    thanks to drdre20013
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  2. The Following 106 Users Say Thank You to dimitar For This Useful Post:
    ACDC (14th May, 2014), Adiadi (4th November, 2021), ahadi (9th May, 2014), ahl (2nd December, 2014), ajonlineservice (7th October, 2019), aksimo (5th May, 2014), alladdin205 (28th June, 2014), andkl2810 (19th May, 2014), angelx431 (6th May, 2014), apv (9th May, 2014), arsulo (14th August, 2016), autoden (26th August, 2014), autohaus (31st October, 2017), automocion (6th May, 2014), baigano (29th May, 2014), bajad (16th August, 2014), bibkare (11th May, 2014), BlacksunLE (7th April, 2017), bochen (5th May, 2014), bokilee (11th February, 2020), brodaty (9th September, 2015), canilodad (31st December, 2018), canoso131 (18th May, 2014), cocutanu (6th May, 2014), Col19 (5th August, 2019), cosmin12345 (10th December, 2014), costas1980 (23rd September, 2015), damian475 (25th May, 2014), dego1500 (9th July, 2014), doktorabg (11th June, 2014), ducky2002 (6th May, 2014), Dunker (1st November, 2015), eliah (20th December, 2015), engin005 (22nd November, 2022), enyckma (20th July, 2016), faze (22nd May, 2014), frigo (5th May, 2014), genius76 (5th May, 2014), gezame (6th May, 2014), habbou (11th January, 2016), hbr (27th July, 2019), iustin73 (6th May, 2014), janusz21 (4th May, 2014), jare1989 (5th October, 2023), javyb (1st July, 2014), jenny123 (6th May, 2014), jesercampos (3rd March, 2024), jihyu (9th May, 2014), jjrp255630 (5th May, 2014), jmac200t (20th January, 2016), jnoroeste (7th May, 2014), jo?o antonio (24th May, 2014), joki_lo (19th November, 2020), jos68 (19th May, 2014), kiramine (5th May, 2014), labtecnomocion (16th November, 2019), lie (19th September, 2019), liviudiaconu (6th May, 2014), lkjubaking (7th May, 2014), lollo54 (21st June, 2014), MACKIE (11th May, 2014), madzar (16th July, 2014), Meat-Head (8th May, 2014), meteinam (17th December, 2019), mexanico1971 (6th May, 2014), mintoe (7th October, 2015), morito (12th May, 2014), MrMike (18th April, 2016), naser (31st August, 2014), neonlight (26th October, 2016), nhsping1 (24th September, 2014), nikeady (22nd December, 2016), Nols Theron (9th November, 2022), nuno50 (10th September, 2014), ombre57 (12th August, 2021), paro44 (6th May, 2014), paul_12345 (10th May, 2014), pinotec (22nd May, 2014), ProblemChild (22nd May, 2021), racin-snake (4th May, 2014), radioman (8th October, 2014), radsky (20th May, 2014), Rinor (20th January, 2019), Rioma (25th September, 2018), rui (1st January, 2016), samyy (7th April, 2017), sarigol45 (28th June, 2022), sasa5 (26th April, 2016), semga (12th February, 2023), Sizwe (10th November, 2022), smilos (2nd November, 2014), soxten (15th June, 2014), sparkytech (16th July, 2014), stefan11 (31st March, 2017), StingEyes (22nd July, 2021), TCSTigersClaw (9th May, 2014), texas auto (10th April, 2018), Toldy (4th March, 2019), tomxx (31st December, 2016), tonyboy101 (8th May, 2014), tourettes (7th April, 2018), uniquuu (16th January, 2017), vladacalibra (4th July, 2014), willyboy28 (6th March, 2019)
  3. #2
    DK Veteran aksimo's Avatar
    Estonia
    Hi can I do firmware update or will it kill my unit ? (hw 1.45,2010 sw)
    Thanks.
    DK is the best !!
    Department of factory errors.
    dimitar's Avatar
    Quote Originally Posted by aksimo View Post
    Thanks.
    i updated mine interface found all ok relays clicking
    50w Soldering Iron
    Chisel
    Sometimes Hammer
    genius76's Avatar
    Dec 2012
    Lowestoft
    relays not mean that working test on car done?
    I can help you but only if you want me to help you
    All the questions should start from what car, what year, what engine is what fuel. What are the symptoms of the problem. Only then is what you know, what fault code, live data, what you have done.
    Dec 2012
    GARAGE
    Hi! Did you try it on car?
    Jun 2009
    Hi, I did a quick test on Astra J 2013 year and it worked well. Connection to all modules. In some of them there are only error reading but anyway it is a big progress since the 2010 version and a light at the and of a tunnel for future updates. Thanks again.
  8. The Following User Says Thank You to bochen For This Useful Post:
  9. #7
    Estonia
    OK I see that can update and works after that
    DK is the best !!
  10. #8
    Don't work to me. I have OPCOM China clone with V2 driver..
    Can you upload here FTDI.ept file?
  11. #9
    Just gave it a try, looks to be spoofing the FTDI ID with some code injection.
    Unfortunately both opcoms I have setup on the same machine (1.39 and 1.45) didn't seem to be detected. The app also wanted to be activated before use.
  12. #10
    If the soft will try to activate your interfaces they could now be killed.
    This version only fakes the FTDI ID to a genuine one. The license in the version is from a genuine user...this interface will now be blocked from future updates.
    That means...no general solution for future updates...sad to see that a version with original license is spread. I have doubts of using it...i mean it seems to work also for me but its really strange.
  13. The Following User Says Thank You to ducky2002 For This Useful Post:
    gazvts (6th May, 2014)
  14. #11
    I have now thinking completly different in mind...what if this version was spread initially from Auto M3? I mean if they could kill many clones at one it would be a success for them...as i read above the version is not working for everyone...really strange. I used a .net disassembler on the loader and there is no special code inside...only injection of a faked FTDI ID...now i have more doubts than before.
  15. #12
    Oct 2008
    heaven
    i try on astra-h working good firmware 1.45
  16. #13
    angelx431's Avatar
    Sep 2010
    BG Sofia Madrid
    Vectra B 2.0 dtl. All work.
  17. #14
    Oct 2008
    heaven
    corsa c z10 work ok ...i hope anybody cracker make 2013 new version cracked opcom
  18. The Following User Says Thank You to argegsm For This Useful Post:
    ilico (27th January, 2016)
  19. #15
    Sep 2011
    opel vivaro 2002 1.9dti work
  20. The Following User Says Thank You to kt315b For This Useful Post:
    keyman1079 (16th July, 2014)
