Page 3 of 9 FirstFirst 12345678 ... LastLast
Results 31 to 45 of 122
  1. #31
    For that peoples with noworking cable, open a new .txt file
    Paste that in him:
    [Basic Details]
    Device Type=6
    VID PID Type=0
    USB VID=0403
    USB PID=6001
    [USB Power Options]
    Bus Powered=1
    Self Powered=0
    Max Bus Power=90
    [USB Serial Number Control]
    Prefix=OP
    Use Fixed Serial Number=1
    Fixed Serial Number=OP-COMV2
    [USB Remote WakeUp]
    Enable Remote WakeUp=1
    [Windows Plug and Play]
    Enable Plug and Play=1
    [USB String Descriptors]
    Manufacturer=AUTO-M3 Ltd.
    Product=OP-COM USB V2
    [Programming Options]
    Only Program Blank Devices=0
    [BM Device Specific Options]
    USB Version Number=1
    Disable Serial Number=0
    IO Pin Pull Down in Suspend=0
    [Dual Device Specific Options A]
    RS 232 mode=1
    245 FIFO mode=0
    245 CPU FIFO mode=0
    OPTO Isolate mode=0
    High Current Drive=0
    [Dual Device Specific Options B]
    RS 232 mode=1
    245 FIFO mode=0
    245 CPU FIFO mode=0
    OPTO Isolate mode=0
    [Dual Device Driver Options A]
    Virtual Com Port Driver=1
    D2XX Driver=0
    [Dual Device Driver Options B]
    D2XX Driver=0
    [R Device Specific Options]
    Invert TXD=0
    Invert RXD=0
    Invert RTS#=0
    Invert CTS#=0
    Invert DTR#=0
    Invert DSR#=0
    Invert DCD#=0
    Invert RI#=0
    C0 Signal=2
    C1 Signal=3
    C2 Signal=0
    C3 Signal=1
    C4 Signal=5
    Enable Ext Osc=0
    High Current I/O=0
    Load D2XX Driver=1
    In EndPoint Size=0
    [DualHS Device Specific Options]
    IFAIsFifo7=0
    IFAIsFifoTar7=0
    IFAIsFastSer7=0
    AIsVCP7=1
    IFBIsFifo7=0
    IFBIsFifoTar7=0
    IFBIsFastSer7=0
    BIsVCP7=1
    IOPinDriveDual=0
    UTMIDrive=0
    UTMIVendor=0
    SuspendOnD7Low=0
    [QuadHS Device Specific Options]
    AIsVCP8=1
    BIsVCP8=1
    CIsVCP8=1
    DIsVCP8=1
    ARIisTXDEN=0
    BRIisTXDEN=0
    CRIisTXDEN=0
    DRIisTXDEN=0
    IOPinDriveQuad=0
    Save the text and change extension in .ept
    Use MProg 3.5 from FTDI and reprogramm FTDI with him.
    use exe driver from 120309 and install driver
    The cable will be "serial converter" but no com port attached (D2XX driver)
    Cable will work with this version and with older chineses versions too..
    For peoples with working cable: see in device manager, your cable after using 120308a is serial converter now, even was OPCOMV2 before..
  2. The Following 22 Users Say Thank You to liviudiaconu For This Useful Post:
    andkl2810 (19th May, 2014), andy99 (20th May, 2014), apv (20th May, 2014), art64 (28th December, 2015), bochen (19th May, 2014), cocutanu (20th May, 2014), enyckma (19th July, 2016), faze (22nd May, 2014), genius76 (19th May, 2014), ilico (27th January, 2016), instakeys (21st June, 2014), jenny123 (24th May, 2014), jihyu (26th May, 2014), jos68 (19th May, 2014), kver (29th May, 2014), paro44 (19th May, 2014), pinotec (22nd May, 2014), prusony (30th June, 2014), racin-snake (22nd May, 2014), sasa5 (26th April, 2016), shifty01 (30th March, 2016), yellowstilo (16th April, 2016)
  3. #32
    Aug 2010
    Gob bless you!! I managed to unbrick my v1.45 op-com clone with your software and your instructions!!
    --edit--
    As I figured out it needs the 2.4.6.0 version of the driver to work otherwise if you use the 2.8.x.x or greater version the clone will become a brick. But you can unbrick it to v01.45 if you install the 2.4.6.0 version of the driver and then run the OPCOM.exe from your program!! I managed to revert the driver in my desktop PC (Win 8.1 Pro) to 2.4.6.0 but I can't do it on my netbook with XP... I will try doing a restore...
    --edit2--
    The driver that is included works like a charm!!! Thanks a lot again!!!
  4. #33
    i don't know what you tell us about drivers, but here, on this pc i have 2.8 driver and work ok to test...on car not tested because this is a PC, not laptop.
    I'll see on laptop what driver is, because i made a diagnose on all controlers of a corsa c 2001 z10 xe. And work fine.
    And the driver included is 2.8.14..
  5. #34
    are the 1.39 capable to work with this too?
    br
  6. #35
    after you made the test and try to diagnose..you'll see the message with updating..
    And Vauxcom will update your cable to 1.45
  7. #36
    Middle Europe
    That?s true,
    but if you don?t make this test v1.39 is working without update !
    I?ve tested before the soft. updated to 1.45 !!
    Now i have 1.45 and works with both versions,my old version und the current 120309a.
    Does someone have a working german version ?
    columbo25
  8. #37
    advice!!!
    If you want to work with older versions..like china 2010, 09xxxx, etc, make downgrade to 1.39...
    for 120309 upgrade to 1.45.
    I don't know how work a version with another fw...can be a disaster for a model car..
    The version is "marriaged" with firmware..
    Because fw is a little programm, like a driver.
    If in 1.39 instructions are : read errors, do something...and in 1.45 is read errors, do something1... the two rutines something and something1..will do different opperations.. in fact a newer fw is not only a "optimized fw", is a "newer fw"...more functions can be rewrited, modified, not only optimized..
  9. The Following User Says Thank You to liviudiaconu For This Useful Post:
    cocutanu (23rd May, 2014)
  10. #38
    N/A
    Works like charm:
    Plenty new features
    THX!
  11. #39
    where can I find 1.45 fw ?
  12. #40
    DK Veteran cocutanu's Avatar
    Jun 2009
    Quote Originally Posted by cosmind View Post
    Give power to your interface (12v), run software, make any test (try connecting to any module no matter if any car is diagnosed - powered interface it's enough), the software will update the firmware for you and restart after that.
    Best Regards
  13. #41
    Thanks. I try without powered interface and dont work. older sw work to update fw without power
  14. #42
    It's cool
    everything works)
    Thanks guys
  15. #43
    Software works (mostly). Automatically updated my device from 1.39 to 1.45.
    Device with new firmware works without problems with old software (8.2010).
    This version has a few glitches. Data logging or any attempt to write to file crashes the software:
    Real-time display of graphs is mostly useless since most of the parameters are unavailable (something about a beta version).
    Few glitches with measuring blocks: sometimes fileds are empty, going back to main menu usually fixes it.
    Data logs format has changed since 8.2010.
  16. #44
    your win is w7? what kind of 7? 32 or 64 bit?
    i don't know if work well on w7.
    Try to set work in compatibility with xp.
    If not, on microsoft exist a virtual xp machine, is about 2 files download and install on w7.
    The two files are different for 32 or 64 bit
  17. The Following User Says Thank You to liviudiaconu For This Useful Post:
    d.milivojevic (15th June, 2014)
  18. #45
    Jun 2014
    Need framework to run. Now runs greate but it did not see my op-com device, my device on fw 1.45. do you have an idea ?
