Results 1 to 4 of 4
    Aug 2013
    Lightbulb Vu+ solo 2 killed
    i brought VU+ solo from China which was clone did not know first but after when i update.When i update The Blackhole Software in that box it kill the box ..does any one can help me please it cast me lot and cant send it back because it too expensive to..
    Sep 2008
    i believe you need a new programmed chip from china soldered into box to bring back to life ,should be a number of posts relating to dead solo2 clones around.
    digicon's Avatar
    You need to contact the supplier who soold you the Box in China and get them to either:
    A: Send you a new Nandflash Chip which you will have to remove the other one and then solder the new one in place (Not an Easy Task)
    B: Take your motherboard out of the Solo2 case and send back to china for them to do the work
    Mar 2019
    Belarus
    Default Vu solo 2 killed
    I bought parts from a couple other guys before buying the brake pads from Solo, and they came first. Thanks
