Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
  1. #16
    ruffles1986's Avatar
    Sep 2011
    In the Garage
    Thanks for your experiences, i will go to check these things
  2. #17
    Oct 2013
    GB
    1) Clean the tank and pipes filings !!!!!!!!!!!!
    2) change pump petrol or checked
    3) Changed petrol pump οr checked
    the car had no pulse injectors, the problem was in the ECU.
  3. #18
    cubica1's Avatar
    Feb 2012
    Serbia
    I had same problem, on the first I have made recallibration 93c46, after that solder again ecu connector pins..and everything is OK! kangoo 1.9d 2002, DCU3R.
    cuby
  4. The Following User Says Thank You to cubica1 For This Useful Post:
    sayonarab (27th June, 2017)
  5. #19
    cubica1's Avatar
    Feb 2012
    Serbia
    Hi @sayonarab,
    I can't send email...here is all,
    try-report,
    regards,
    cuby
  6. The Following 14 Users Say Thank You to cubica1 For This Useful Post:
    BusCan (10th September, 2018), clc79 (9th November, 2023), ivica21 (19th July, 2018), joker007 (27th March, 2019), LabraxDz (1st February, 2021), mapexo (18th July, 2018), mexanico1971 (4th September, 2018), mijatx (3rd August, 2017), Puhi7799 (10th March, 2021), rrr500 (27th June, 2018), sanden134 (20th February, 2023), sayonarab (8th July, 2017), Stelaras26 (22nd March, 2018), vaidas89 (20th October, 2017)
  7. #20
    Jul 2012
    Thank you very much cubica.Do you know how I can read the osm value in the ecu to write the same value on the osm sensor? I suposse that the value must be the same so i Think:
    1. Read the ecu value
    2. modify the osm value.
    Right?
  8. #21
    Aug 2016
    Thanks. Good info
