Results 1 to 15 of 28
    DK Veteran gtmech's Avatar
    Hell
    Default Anyone triedto read this Alfa ECU before?
    2003 Alfa 156 2.0TS, tried to read with Galetto but got message about pin 20 to MASS and couldnt understand what it meant. Anyone know how I can read this as I need to virginise it, thanks
    Hi, You must read and write in boot mode - it needs connect pin 20 to GND. I attached image with connection for that ECU.
    they are is immooff for this ecu if need?
    Hell
    Quote Originally Posted by zoyzoyni View Post
    you can immo off this ecu mate?
    yes i have posted before one year about.i will search for the files cause sinse then my pc one time stolen and secont time hdd burn.post dump
    Hell
    ok will post the dump, thanks buddy
    Hell
    Quote Originally Posted by electrix View Post
    thanks alot for this buddy
    Hell
    How the F**K do you get this barstard in BOOT Mode???? Tried the 10k resistor trick with no luck
    Am using the CLONE Galetto, is that my problem, will the clone not work? Any idea guys? thanks alot
    With wich Tool do you do you want read this ecu?
    Quote Originally Posted by gtmech View Post
    Connect boot pin directly to GND, without resistor. And it must be connected all the time when You read or write, not only at the begining. Tested and works on many Fiat/Alfa/Lancia ME7.3 ECUs.
    BTW. For sure it works with MPPS and FGTech.
    yellowstilo's Avatar
    boot pin must be connected before powering the ecu....
    Hell
    Yeh i tried not using the resistor to start with and no success so thats why i tried the resistor but it makes no difference. Have you tested with Galetto clone? Maybe thats my problem
  13. #13
    Hell
    Quote Originally Posted by yellowstilo View Post
    tried that to, makes no difference, ive tried everything. This Galetto clone refuses to read it
  14. #14
    Hell
    Quote Originally Posted by bambula tuner View Post
    ive already said mate, im using the Galetto clone, thats all i have at the moment, what too do you use?
  15. #15
    Sep 2012
    portugal
    Pin 15,16,32,47,48 + 12v. Pin 24,25,49 -12v. Pin 20 boot . Pin 53 kline.
    If help press thanks
