Results 1 to 7 of 7
Thread: Trionic8
    Top Poster zodiname's Avatar
    Default Trionic8
    Have any one this script Universal BDM scripts for Trionic 1_2.zip from this site Universal BD32 scripts for Trionic5.x, 7 and 8 ECUs
    because I not have permission to access this page.(file)
    solved , i find
    Wysłane z mojego SM-G386F przy użyciu Tapatalka
    Rito's Avatar
    Post here Where you found?
    Maybe you looking for it?
    Tuning ECU | Hardware and software solutions
    Top Poster VRPerformance's Avatar
    Bulgaria
    post here,i wont to see them also
    ECU Tuning, DPF and FAP remove,EGR remove, Flap remove,DTC remove,Dyno tested files!!!
    soxten's Avatar
    Mar 2013
    Here is how to clone Trionic8
    Working 100%
    Easy way to do this is
    1:Read broken ecu by can (fgtech) and save "original.can.bin"
    2:swap byte in file and save as "original.bdm.bin"
    You have now 2 files!
    3: program used ecu by fgtech BDM with "original.bdm.bin"
    OR program flash by desolder flash and program with Wellon with file "original.bdm.bin"
    (I like to desolder and program on my wellon)
    4rogram used ecu by fgtech can with file "original.can.bin""
    Mount in car and start!
    hy i reed flash from old ecu now car start but run like hell i need swap byte from bin can you doo this
    Jan 2016
    Quote Originally Posted by soxten View Post
    Working 100%
    Hi Soxten
    I have same ecu from Fiat Croma 2.2 ( tronic 8 ) and need to clone to donor ecu.
    you say : 1:Read broken ecu by can (fgtech) and save "original.can.bin...... I dont see in the menu of Galetto this ecu,,,Need I to use menu of Saab by OBD ?
    or need I to choese JTAG BDM MC33xxx in galetto ?
    this my ecu 12598024ab g04001 but car is far way
    thank you
