starview hd combo cable option
Results 1 to 10 of 10
    Default starview hd combo cable option
    i need some info, does the starview Hd have any firmware that would allow me to have cable, as you know cable sealion is possible but the starview hd combo used to connect automatically via ustream
    was thinking about buying an amiko hd cable box but thought i would ask around first to see if it was possible with the starview hd combo running a firmware update
    Junior Member jon50's Avatar
    Mar 2014
    greater manchester
    Hi m8 ive got the same box and i also need info as well
    Feb 2009
    I am also curious about sv hd combo firmware
    Sep 2008
    think that box is closed source on cable file,only opens on sat with alternative firmware.
    Quote Originally Posted by cactikid View Post
    yes i did think that, im running the spiderbox firmware for sat side but wanted to see if there were any options before i bought the amiko hd
    DK Veteran vorlon2257's Avatar
    Sep 2011
    Vorlon Homeworld
    I think all you have to do is put your HD Combo back to being a HD Combo using the correct firmwars etc.. and then enter your details ( if you know what I mean) just like you did for Satellite side of it. But really guys it's such an old box now is it really worth it, I've got 2 of them and when I get the money together I've investing in a more upto date box/s and retiring the 2 of them to a cardboard box to be put into the loft.
    There are much better alternatives now to the HD Combo.
    Apr 2011
    Default Starview Combo +
    Starview Combo lan.Only !You can use them on cable,(with c/s)
    with carling 531.works fine,
    cheers..
  8. The Following 4 Users Say Thank You to electral For This Useful Post:
    12345guy12345 (19th May, 2017), cactikid (31st December, 2014), jon50 (2nd January, 2015), microchip11uk (9th January, 2015)
    Sep 2008
    dam its in downloads nice one m8,thought it was a goner by now.
  10. The Following User Says Thank You to cactikid For This Useful Post:
    electral (31st December, 2014)
  11. #9
    Apr 2011
    dont use live links m8 its a nono
    Sorry m8.didn't realise it was a no no.
    cheers..
  12. #10
    Sep 2008
    i checked later and saw it was to dk =ok ,if it was an outside link be worried as you see i edited my post when i checked again .cheers.
  13. The Following User Says Thank You to cactikid For This Useful Post:
