Page 2 of 80 FirstFirst 12345671252 ... LastLast
Results 16 to 30 of 1195
  1. #16
    Nov 2012
    HUSI- ROMANIA
    VIN: WVWZZZ3CZAE151309
    PIN: 63851
    Component Security Bytes: F3 2B 85 E1 E6 57 0B
  2. The Following User Says Thank You to vorovei constantin For This Useful Post:
    zippy82 (15th October, 2014)
  3. #17
    Default PASSAT CC 2013
    Please calculated CS and Pin code for WV CC 2013 and thanks
  4. #18
    Nov 2012
    HUSI- ROMANIA
    VIN: WVWZZZ3CZCE716985
    PIN: 12226
    Component Security Bytes: 8D 9B FC 83 69 B4 BA
  5. #19
    Default Passat Comfort activate key
    Hi please is possible activated key?In dump is 2 keys but vcds shows 0 adapt key.Key is original!And pls search CS Bytes.
    Thanks Tonda
  6. The Following User Says Thank You to Tonda For This Useful Post:
    MVVL (7th April, 2023)
  7. #20
    Nov 2012
    HUSI- ROMANIA
    for
    passat 95320,rar
    VIN: WVWZZZ3CZ6P037395
    PIN: 35838
    Component Security Bytes: 12 B9 85 EA 25 73 0B
  8. The Following User Says Thank You to vorovei constantin For This Useful Post:
    Tonda (18th October, 2014)
  9. #21
    Thanks for quick reply,is possible get status ON for keys 1 and 2?Comfort module not accept pin after 30 min ac on. And vcds show in measurement block 0 adapt key when i have original keys. I think keys are blocked and need keys unblock.
  10. #22
    No possible repair it?
  11. #23
    Jan 2011
    Slovenia
    hello
    can someone help with CS and pin from ccm?
    thanks in advance
  12. #24
    Moderator
    PremierD's Avatar
    Jun 2009
    Yes mate we can .....
    VIN: WVWZZZ3CZAE111078
    PIN: 29995
    Component Security Bytes: 59 21 1A D6 B2 42 35
  13. The Following User Says Thank You to PremierD For This Useful Post:
    leonel (25th October, 2014)
  14. #25
    Hi leonel,
    you have problem with keylearning only,or problem with block key.
  15. #26
    Jan 2011
    Slovenia
    problem solved!
    Thanks PremierD
  16. #27
    DK Veteran JIMMYQ's Avatar
    Mar 2008
    apart from avdi/tango and tm100 is there any other software/hardware that calculates this?
  17. #28
    Szczecin;Poland
    Pin and CS please
    No army may enter that land
    That is protected by polish hand
    Unless you are 40 to 1
    Your force will soon be undone
  18. #29
    gwee's Avatar
    Dec 2012
    unknown
    VIN: WVWZZZ3CZ8E008087
    PIN: 26545
    Component Security Bytes: C5 CB 49 81 8B 96 93
  19. The Following User Says Thank You to gwee For This Useful Post:
    bugajewski_pl (29th October, 2014)
  20. #30
    Quote Originally Posted by JIMMYQ View Post
    At this point not known. Tango seems to be first and best for it.
