Page 30 of 80 FirstFirst ... 20252627282930313233343540 ... LastLast
Results 436 to 450 of 1195
  1. #436
    Jan 2016
    Austria
    Quote Originally Posted by alex09 View Post
    Thank you Dunt you are a life savier , i am starting to get realy desperate with these car. Still one question when i try to enter this info in immo it ask for some immo data 28 bytes, what is that.
    What you try to do? Which Software you use?
  2. #437
    alex09's Avatar
    Apr 2013
    Serbia
    Ive been lost all info in ccm and immo, and now trying to eneble immo with VAS pc 19.1. It ask for VIN which i have, immo Id which you provide, and immobiliser data 28 bytes hexadecimal, and underneath i got option to check (input of RESULT encrypted) its optional. You might have experience with that. Sorry Dunt i dont know how to paste recent post. My ccm and immo have lost all data, its all zeros no id no nothing just 3c0959433m.
  3. #438
    alex09's Avatar
    Apr 2013
    Serbia
    Please does somebody know how can i solve this problem? Someone ...
  4. #439
    Jan 2016
    Austria
    I think VAS PC only can adapt CCM online. Which Dump I decrypt for you is this not the orginal Dump from your car?
  5. #440
    alex09's Avatar
    Apr 2013
    Serbia
    Quote Originally Posted by dunt View Post
    . Hi dunt, yes it is original dump from ccm, ive read it with carprog verify few times and saved. I somehow lost VIN number and Immo ID, i dont seen them in immobiliser. And there is no fault code in 25 immobiliser.
  6. #441
    alex09
    Test it and let it know if it works
    repair Copy of ccm passat 2.0tdi ppd1.2.zip
  7. #442
    alex09's Avatar
    Apr 2013
    Serbia
    Quote Originally Posted by ciekawy View Post
    alex09
    Hi Ciekawy, first thanks for reply, i have try this dump you repair, now i got fault 02823 Requirements for locking the steering column not met. I didnt have that fault before. And still dont see in MVB chassis number and ID of immo. And car still starts than stop after 2sec.
  8. #443
    Member feti589's Avatar
    Hello guys
    If somebody cqn give me pin and cs for this passat b6
    here read from 95320 from ccm
    thanks for your help
  9. #444
    Very damaged dump
  10. #445
    alex09's Avatar
    Apr 2013
    Serbia
    Please someone, i cant solve the problem, seems that all the data are in the dump buth still cant get car to start. When i go in CCM with VCDS MVB 011 theres all no value regarded to immobiliser. And when i go in 25 Immobiliser with VCDS MVB 081 and 082 all xxxxxxxxxx, and should be VIN number and Immo ID. And immobiliser status in MVB is ( 0 ). No clue what should i do? If someone can help?
  11. #446
    test repair1
  12. #447
    alex09's Avatar
    Apr 2013
    Serbia
    eeprom ECU siemens ppd1.2.rar
    test repair1
    Still the same Ciekawy, i still have same fault, and car does not start. i will post dump from the ECU, if you can check if its all right.
    Iam pretty confused about this car. everything is there no faults except in engine ECU, start blocked by immobiliser.
  13. #448
    Apr 2011
    need CS and pin code.
    Thanks in advanced
    Mat
  14. #449
    rola1971's Avatar
    Jun 2014
    Dublin
    Quote Originally Posted by mcgywer View Post
    Thanks in advanced
    Mat
    VIN: WVWZZZ3CZ7E190700
    PIN: 30205
    Component Security Bytes: 60 B8 C7 2A C1 71 8E
    good luck
  15. The Following User Says Thank You to rola1971 For This Useful Post:
    mcgywer (5th May, 2017)
  16. #450
    hello
    need CS PIN and VIN for the passat keyless comfort module
    thanks in advance for your help
