Page 37 of 80 FirstFirst ... 27323334353637383940414247 ... LastLast
Results 541 to 555 of 1195
  1. #541
    qwertyuiop12's Avatar
    May 2013
    Thanks friend,please need ID keys
  2. #542
    CarCity's Avatar
    Nov 2016
    Inside my clothes
    Quote Originally Posted by qwertyuiop12 View Post
    Key 1 : B9DBDB7D
    Key 2 : C25C2A73
    I surprise those who do not want to use the Thanks and Reputation buttons but ask for the password of the files.
  3. The Following User Says Thank You to CarCity For This Useful Post:
    qwertyuiop12 (21st November, 2017)
  4. #543
    Default hello, can you give me cs, pin and keys, thanks in advance
  5. #544
    CarCity's Avatar
    Nov 2016
    Inside my clothes
    Quote Originally Posted by lurossi View Post
    VIN : WVWJA83C26P101093
    PIN : 26501
    CS : F9 6D 96 35 F2 DB 2C
  6. The Following User Says Thank You to CarCity For This Useful Post:
    lurossi (23rd November, 2017)
  7. #545
    Nov 2017
    I need pin CS and MAC
  8. #546
    Member trivilin8's Avatar
    Mexico
    Hello everyone, I wonder if you could help me to get immo off on a 2007 2.0 TFSI, I have tried to make it work with immo but I'm tired already. I changed ESCL, CCM, Steering column and switch and allways values on immo keep showing that no key is programed and no valid transponder. I used tango to write another key directly on eeprom, and says the same thing, and tango says theres 2 keys programed. I was goning to try to make immo off file, I was trying with FVDI with dump file, but when I load eprom bin FVDI ask me to load flash file as well. Wich im not pretty sure if its D43256BGU, I thought I was going to be able to read flash with kess, but it just give me a file with no options to choose if I want to read flash and eprom or just one of each.
    These are the two files a have so far, I hope you could help me any how. I also attached ccm eprom if you need, and another ccm eprom, the one i tried with but i didnt even bother to check CS data becaus says has no key programed, and I took that CCM from a crashed car, so, I think it has to have a prgramed key.
    Any Help would be really apreciated Thanks in advance.
  9. #547
    CarCity's Avatar
    Nov 2016
    Inside my clothes
    Quote Originally Posted by danigti View Post
    Probably CS and MAC is incorrect only PIN : 55769
  10. #548
    yugo45's Avatar
    Anyone knows what online tool is this?
    Quote Originally Posted by eltiobarbas View Post
  11. The Following User Says Thank You to yugo45 For This Useful Post:
    rob h (14th December, 2017)
  12. #549
    Gavra's Avatar
    Belgrade/Melbourne
    Quote Originally Posted by trivilin8 View Post
    Used CCM data:
    VIN:WVWAK73C77P108842
    MAC: 07BC5024
    CS: E43CD405C879A8
    PIN: 59584
    power class: 80
    ELV: 548E
    1 key coded
    ORI CCM data:
    VIN: WVWFU73C97P002540
    MAC: 4B45C396
    CS: FDDABD37FBB57A
    PIN: 23887
    power class: B6
    ELV: 6246
    2 keys coded
    Guided fault finding = Feature that many factory scan-tools have and real technician despise it.
  13. The Following User Says Thank You to Gavra For This Useful Post:
    trivilin8 (14th December, 2017)
  14. #550
    Mexico
    Quote Originally Posted by Gavra View Post
    Used CCM data:
    MAC: 07BC5024
    CS: E43CD405C879A8
    PIN: 59584
    power class: 80
    ELV: 548E
    1 key coded
    ORI CCM data:
    MAC: 4B45C396
    CS: FDDABD37FBB57A
    PIN: 23887
    power class: B6
    ELV: 6246
    2 keys coded
    Thanks a lot Gavra, I gave up with that car, the owner was in a bad way to me already, The only thing left to try with, was the ECM. I Have the rest of the parts I got to test and hopefully use them further to recover what I invested, your info is going to be really helpful to make them work. One more thing, a guy told me a used ELV cannot be adapted, is it true? Are the numbers 548E and 6246 used to adapt ELV?
    Can any module that is linked to immo be adapted?
    Thanks again for your help
  15. #551
    Jan 2016
    Yes, used ELV cant be adapted unless you resolder MCU's from ori to used one.
  16. #552
    szengen's Avatar
    Jan 2017
    Default please pin cs
    please pin cs95080-.rarcentral electrician
    fang, Narwalus microcephalus,Spectrum Zx, Atari amiga, Commodore +4
  17. #553
    rola1971's Avatar
    Jun 2014
    Dublin
    Quote Originally Posted by szengen View Post
    what this?
    may be you write info from where this 95080?
  18. The Following User Says Thank You to rola1971 For This Useful Post:
    szengen (18th December, 2017)
  19. #554
    autochei's Avatar
    Mar 2013
    romania
    read 95320 from confort
  20. The Following User Says Thank You to autochei For This Useful Post:
  21. #555
    szengen's Avatar
    Jan 2017
    Default comfort 95320
    comfort 9532095320-.rar
