szengen (18th December, 2017)
can i have pin please
pin: 38165 cs: 84 3E EB 61 67 C2 C3
Hi everybody. I need the help of the 2006 1.6Fsi Passat, i need 3c0959433m virgin dump. I bought an original new ELV and a used Comfort Controller (3c0959433m).I would like to re-program with Odis-online. Thanks !
I accidentally put the immobilizer in the "factory mode" mode with the vagcom. Now the car does not recognize the keys and I can not start. I believe that the VIN of the immobilizer was also erased. I have the pin code of the car i have the fvdi i vagcom. Please help, how can I solve this?
I think Yugo he dosnt have backup. Just learn keys with vagcom by PIN. IMMO 25.
Wysłane z mojego SM-G950F przy użyciu Tapatalka
yugo45 (11th January, 2018)
Hello
I do not have saved the original dump
So try to learn original keys with VCDS by PIN.
Solved! Thanks
Can someone calculate pin from 3c0959433h, passat 2006
Thank you
bmc (17th January, 2018)
Hello I need please PIN/VIN /CS from passat confort module 3c0 959 433
cs 83EF46AB07DE8D
pin 12810
bcm2 elv adapt online offline -echange immodata -clone immodata sinchro bcm elv medc17 edc17 Crafter EZS e EDC17 sinchro -DPF/ EGR/ DTC/ removal/: IMMO ADAPT edc16 EDC17 edc17c64 C74 NOW WORKING MED17/MEV17/ VAG ecu clone full working all
PCR2.1 FULL CLONE ou adapt, clone all edc17 me17 , etc / dash echange immodata repair immodata add key etc etc
venelek (17th January, 2018)
