Saulius Saulius (18th June, 2015)
I need change steering ELV and code it. I did it before few times, but allways was megamos 48, here first time pcf7936 ID46 keyless system, maybe sequence wrong... Car did not start at all, client come and we try to change steering lock and stuck on password accepting, now car did not start on old ELV. So we can't code new one from dealer and car did not start on old one...
MagicMotorsport FLEX, Kess / K-Tag original, PCM Flash, MMC Flasher, BitBox, 2wd Dynomet Dyno Road, Ori WinOls.
We offer: Cars, Trucks, Agro, Construction Machines Tuning / DPF / EGR / Flaps / Throttle / Ad Blue / Lambda / DTC, IMMO off. Also EDC17 IMMO off BY EEPROM with no faults on a dash!
Write old dump then old should work again.
Dump is old... I did not change dump, I read it just to get PIN code. Any Ideas?
[25-Immobilizer]
[Adaption - 10]
Leave channel at "00"
[Read]
[Save]
[Done, Go Back]
[Security Access-16]
Enter the vehicle PIN in a 5 digit format. ON THIS STEP I STUCK! DO NOT ACCEPTING PIN!
[Do it!]
[Adaption - 10]
Read Channel 051.
The Stored Value will be 32000. Enter the PIN in the New Value box.
[Test]
Wait | N/A | N/A | N/A Will be displayed. Wait until the ID numbers
are transferred into the first 2 boxes. If you aren't sure, be patient
and wait at least 30 seconds!
[Save] (Note: if Save is not available and the data in the last step has
transferred continue by exiting)
[Done, Go Back]
Now I can't start with old ELV, maybe it heapened after first step?
[25-Immobilizer]
[Adaption - 10]
[Read]
[Save]
[Done, Go Back]
Yes,rewrite the dump you read and steering lock will work again.
Dump which I read before first step?
Yes. Exactly this dump.
I put old dump back, everything the same, no ignition, go to VW main dealer and bought ignition lock, put it... nothing... then I open old lock and found one bad micro switch, take it from new lock (which I can't program) put in old and... nothing!!!... Take new mechanism and put it in old lock... nothing...
Key good, remote control working, chip good, I can read it with tm100 and tag tool...
I did not say before, but when I putting key in a ignition lock, steering lock locking unlocking locking unlocking again and again... on a dash yelow steering light and message: turn steering wheel, after other message: steering wheel still locked...
Lock just on a cables, I did not put it in a place still no good result...
Solved! Thank you all for help!
It will be good when you share where was problem.
I solved last variant where I changed switch. It was need did it fast, so forget about small lock on a top of steering lock, when you opening cover it locking Steering lock. So it was small problem... But why I can't code new one I don't know...
Please calculated CS and Pin code for WV PASSAT 2008 and thanksbcmVW PASSAT 2008 B6 95320.rar
VIN: WVWLT83C98P059253
PIN: 32106
Component Security Bytes: 64 87 1A 3A C9 0E 34
will that suffice mate
datapage (25th June, 2015), gwee (26th June, 2015), Johnner (25th June, 2015), lupu_sandu (25th June, 2015)
UUUUUUUUUU car work.... tks PremierD
Dear Friend. could support me with the security code to this file VW Passat?
Thank you for your help
