gttuning (13th November, 2015)
Guys, is Passat B6 remote reusable? Some models keys are with id48 and some with id46, does somebody know more about this?
thank you in advance
Hello.
1) yes in passat we have 2 kind remote key, (1) smart remote with transponder Id48,(2) smart remote with id46 = (HITAG) + (keyless go).
2) you can dismount the remote and change transponder id48,after you can relearn it to Comport-M + you can adapt the remote too to Comfort-M.
3) & about remote with id46 (for HITAG)you can read comfort-M dump,& after by tango prepare it,& after learn it by obd2 the transponder & after when done the learning producer it self can done the remote locking & unlocking, (use VCDS) to learn it.
Thanks mate, I heard many rumors about this...this is very clear information thank you very much
Hi....how to calculate MAC the file knowing CS :
pin 0F 9F xor DA DA = D5 45 = 54597
pic2 xor:
Premier this is virgine file from a new comfort. Check what will the program (pin , cs , vin ).
I get unknown version .. with Tm....will try again after update
filutek (3rd December, 2015)
It seems to me that they do not recognize because they do not get credited the ELVs . Each adding ELV changes the encoding xor file in comfort.
Each manual change EEPROM bytes in a file causes an error.
PremierD (3rd December, 2015)
Can I have please the cs and pin?
Here you go.
PIN: 15057
Component Security Bytes: 1B 65 21 82 36 CA 43
And MAC .... 3D 63 E8 4D............ I think ...
I am looking for a solution
please i need passat login and cs
