Page 10 of 80 FirstFirst ... 567891011121314152060 ... LastLast
Results 136 to 150 of 1199
  1. #136
    Moderator
    PremierD's Avatar
    Jun 2009
    Quote Originally Posted by kt315b View Post
    Hello.
    I need PIN, VIN and CS from this Comfort module
    VIN: WVWZZZ3CZ7Z001337
    PIN: 48871
    Component Security Bytes: 57 A2 35 9C AF 44 6B
    That do mate ... ?
  2. The Following 3 Users Say Thank You to PremierD For This Useful Post:
    cjawahir (13th November, 2015), kt315b (13th November, 2015), yugo45 (16th November, 2015)
  3. #137
    Dufner
    Johnner's Avatar
    Jun 2010
    Éire
    Hello.
    FFS,at least stick in a " Thank you in advance ".....
  4. The Following User Says Thank You to Johnner For This Useful Post:
    gttuning (13th November, 2015)
  5. #138
    mikajna's Avatar
    Mar 2015
    Guys, is Passat B6 remote reusable? Some models keys are with id48 and some with id46, does somebody know more about this?
    thank you in advance
  6. #139
    Apr 2011
    in lebanon
    Quote Originally Posted by mikajna View Post
    Hello.
    1) yes in passat we have 2 kind remote key, (1) smart remote with transponder Id48,(2) smart remote with id46 = (HITAG) + (keyless go).
    2) you can dismount the remote and change transponder id48,after you can relearn it to Comport-M + you can adapt the remote too to Comfort-M.
    3) & about remote with id46 (for HITAG)you can read comfort-M dump,& after by tango prepare it,& after learn it by obd2 the transponder & after when done the learning producer it self can done the remote locking & unlocking, (use VCDS) to learn it.
  7. The Following 3 Users Say Thank You to haroutioun For This Useful Post:
    clauberty (28th November, 2018), HeXeN (29th November, 2015), mikajna (16th November, 2015)
  8. #140
    mikajna's Avatar
    Mar 2015
    Thanks mate, I heard many rumors about this...this is very clear information thank you very much
  9. #141
    filutek's Avatar
    Aug 2009
    Silesia
    Hi....how to calculate MAC the file knowing CS :
    pin 0F 9F xor DA DA = D5 45 = 54597
    pic2 xor:
  10. The Following 8 Users Say Thank You to filutek For This Useful Post:
    cjawahir (3rd December, 2015), clauberty (28th November, 2018), got (4th December, 2015), Johnner (3rd December, 2015), M3L3R (12th February, 2016), PremierD (3rd December, 2015), ray-ray (3rd December, 2015), vanos batam (4th December, 2015)
  11. #142
    filutek's Avatar
    Aug 2009
    Silesia
    Premier this is virgine file from a new comfort. Check what will the program (pin , cs , vin ).
  12. #143
    Moderator
    PremierD's Avatar
    Jun 2009
    I get unknown version .. with Tm....will try again after update
  13. The Following User Says Thank You to PremierD For This Useful Post:
    filutek (3rd December, 2015)
  14. #144
    filutek's Avatar
    Aug 2009
    Silesia
    It seems to me that they do not recognize because they do not get credited the ELVs . Each adding ELV changes the encoding xor file in comfort.
    Each manual change EEPROM bytes in a file causes an error.
  15. The Following User Says Thank You to filutek For This Useful Post:
  16. #145
    Feb 2015
    London
    Can I have please the cs and pin?
  17. #146
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    Here you go.
    PIN: 15057
    Component Security Bytes: 1B 65 21 82 36 CA 43
  18. #147
    Moderator
    PremierD's Avatar
    Jun 2009
    And MAC .... 3D 63 E8 4D............ I think ...
  19. #148
    Oct 2015
    Quote Originally Posted by filutek View Post
    xor DA DA
    How to count the xor?? In eeprom adress x5B9-x5BA is hex EF D1. What to do to get DA DA??
  20. #149
    filutek's Avatar
    Aug 2009
    Silesia
    I am looking for a solution
  21. The Following 2 Users Say Thank You to filutek For This Useful Post:
    Olexy (4th December, 2015), PremierD (4th December, 2015)
  22. #150
    please i need passat login and cs
