got the internet cable in and cable lead in do i need to connect to pc as well
M8 have you updated the receiver & I-Connector with the latest firmware???
SLOWLY, OUR FREEDOM IS BEING ERASED.
SOON, WE WILL JUST BE A NUMBER.
IF WE DON'T FOLLOW, WE WILL BE ERASED.
me thinks you have a 780 instead.
Hi.
What programme do i need to donwnload this.
Cheers.
Digital Kaos - Downloads - Kryptview A780 Firmware
needs an update by s/w online update.
Digital Kaos - Downloads - Arnet Kryptview Loader
hi all,
i have a a750 box. when i connect it to the tv, it says bad or no connection. this happen 3-4 years ago, but since then i never used it until i was emptying the cupbaord and i found it. would upgrading the firmware cure the problem i have? any reply will be appreciated.
if you dont have an iconnect it wont work,that box was out pre n3 and worked and only worked after with an iconnect.firmwares and iconnect updates needed for both to work.
Hi guys i have the evolution a780, do i use the same firmware as the arnet kryptview a780 in the download section?
thanks alot.I have managed to load the firmware and i am trying to do an s/w update,but nothing seems to be happening.The progress bar is not moving at all.
I have connected the box directly to VM superhub router using LAN cable.I just checked the weather and traffic information to see whether there is an internet connectiin, and i was able to get the weather and traffic report,which, atleast means that there is no problem with the connection.
https://www.box.com/s/2voczvxdde0r0tk95vjq
s/w update from that.
hey guys help me out too/
i wanna download the latest firmware but unable to do so
latest s/w on line only flash with april 12 u should be good to go.
i just recieved my new kv a780 ... could anyone please guide me on how to get it running ..... i'm new to this .... pleaseee help....
