bin file is in kv downloads which you probably found by now.
Hi need help.
Bought a new A780 from Ebay, also bought a Null Modem cable with it.
I download the loader and file from this site.
when i try to Flash, the message come ( the download not requested )
i follow the steps for 100 times with box turning on and off
but same message. if the box is ON then the message take a little while to popup.
but if I press start then turn on the box, the message popup same moment.
any idea?
I try to change the COM port also, no use.
IF IT DOES NOT WORK FIRST TIME,CHECK YOUR DOING IT RIGHT AND TRY AGAIN,MAKE SURE ITS THE LATEST FIRMWARE. I KNOW - IT HAPPEND TO ME!
@dinga theres nothing bettewr than seeing problems being given advice on but could i just point out "23rd February, 2014" that was the last date somebody asked a question id be worrying if it took half a year to get a problem answered i was having but like i said its great to see new members gettuing stuck in with advice n1 m8
lets give it a try
just to point out some may get issues when it comes to com ports and changing them i wont get into that this TUT is very detailed enough but i did run into 1 issue today when redoing the firmware update and changing the com ports via device manager on my windows 7 32bit when changed the com ports the file gave out a transfer error regarding the settings not being found for the com port 1 in the end i left it at what it was mine was 6 and on the Download Tool i changed the com port on there from 1 to 6 and the transfer went through with no problems at all
when i had a box on the kv loader try com1 or 2 or 3 or 4 when you know you have a 100% null modem cable and dont forget box powered off at rear then on and press download.
factory reset/rescan from main coaxial feed.
thanks to all the team just upgraded my box with usb /null modem cable xcellent
new update showing on box?
any ideas guys its doing my nut in
Download complete last time I was this happy I had just lost my cherry,
I think this was the same issue that spice was posting about I just changed to another usb port left the port settings alone and changed it on the stb happy days (Ive just realised I havent checked the box yet ) cheers guys keep up the good work
hi made were do i get the kryptview loader ive downloaded the firmare file via win zip i think what do i do now ive connected box to laptop aswell and now im stuck
loader
help videos.Code:https://app.box.com/s/ecf9ca7d13cbf06dc043/1/337848024/2721371392/1
https://www.youtube.com/watch?v=Q2RbdhH7_b4
https://www.youtube.com/watch?v=LsEvfBnceiM
Last edited by satsmo; 20th January, 2015 at 10:45 PM. Reason: For future reference please code download links that are on servers outside of DK
Thanks mate I flashed it but still glitchy and I did a scan etc but it does still start the sw update online is this normal as it normally says already updated making me think I've done wrong thanks again for your time
