Kryptview Firmware Loading Guide / Tutorial. - Page 3
Page 3 of 33 FirstFirst 1234567813 ... LastLast
Results 31 to 45 of 486
  1. #31
    Sep 2008
    Quote Originally Posted by qkhalil View Post
    will this firmware upgrade work for arnet a700c
    nope only this will work.
  2. #32
    Quote Originally Posted by boxboy View Post
    Can I use the STB Editor to edit my channels and then upload them to the box? If so, How? I have tried the send and recieve functions and nothing happens, the software tells me that the operation was not requested.
    hi i've got the same problem ""download not requested"" bin at it 24hrs did you solve it any ideas thanks bry
  3. #33
    V.I.P. Member barrowmanandrew's Avatar
    scotland
    on the downloader, make sure you have selected the correct port
  4. #34
    how do you know if its the right port or not?
  5. #35
    Sep 2008
    if it is the right one it will download.
  6. #36
    V.I.P. Member jumpinjo's Avatar
    Apr 2008
    Quote Originally Posted by bigbry View Post
    check what comport your pc is on in device manager and select same from menu on downloader
  7. #37
    DW190
    Guest
    Consider myself an expert on Kryptviews but couldn't have done better than this tut. Great detailed instructions and downloads.
    Never needed it myself.
    Three cheers for the OP.
  8. #38
    Sep 2010
    never downloaded anything in my life,complete novice,dont ask how,but mission accomplished,up and running like a dream,thanks,great site
  9. #39
    Sep 2010
    Default latest update
    What is the date on the lastest firmware for the arnet box
  10. #40
    Sep 2010
    Quote Originally Posted by jumpinjo View Post
    I've tried port 1 and 2 (as it says this on my device manager), but still get the error "The downloading is not requested".
    What now?
  11. #41
    scotland
    Quote Originally Posted by fuzzy19 View Post
    What now?
    press download , then switch you box off and on
  12. #42
    Sep 2010
    London
    2 hrs later all done - that includes goin to maplns n gettin cables, and huntin for spare ether cab 4 30 mins..
    good one fair play
  13. #43
    Does this box work in areas with N3?
  14. #44
    DK Veteran jckw's Avatar
    Sep 2008
    am i right in saying these boxes need to be connected to the internet via a router using the lan port
    we are all learning each day
  15. #45
    yes ethernet into box then one of ur routers ports
