I think I will have to get a new usb connector as it did not come with a disk and there is no details of make or model anywhere on it.
Hi again I have got a new usb adaptor and have now installed it so I can see which port needs to be used com 4 on mine, I have everything else in place but when I try to flash the box I get the download not requested message, I have been through the Tut several times and have trawled the replies on all these pages and tried all the advice and still nothing, can someone please help
best to s/w update by lan to newest firmware.
omg holy crap it works wow and somebody wanted to charge me ?10 for this thz every1 for your help and support i still cant believe i did this
i would have charged you ?20 .have you updated on the internet to the 24042011 firmware yet?if not go to menu-system info-s/w update and ok let box update to new firmware and box reboots,factory reset and rescan without lan connected,when channels loaded insert lan power off box at rear and modem and router for 30 secs then on.
Will this work with windows XP?
i updated with this Kryptview_A750_03012011 with usb connector which i brought coz my laptop did not have 9pin connector anyway thx again but yesterday all the channels went (only few were coming including the channels i watch which are sky sports but now they are gone again) what do you suggest i should do wait until they come back )
i do use the kryptview a750 with i connect
the s/w update is on your firmware which you use to connect to internet. menu...installation....s/w update,,allow box to reboot,dont touch anything until done,then factory reset and rescan as above as in 229
links please. thanks in advance
Thanks for sharing and giving nice instruction.
I have a750 box i have followed your instruction but i couldn't download firmware as it say "Download Fail" i think i am stuck in last step.
I did connect using null usb adopter then i turned of the box then i clicked on "START" after 3 seconds i plugged in box then computer screen show downloading 0%, after few seconds it says "Download Fail"
any help would be appreciate..
if you have the jan firmware on box you should have the option
to s/w upgrade with remote no cables or pc needed
I got A750. thanks for replying but when i Click on "S/W Transfer" that doesn't do anything!! can you tell me where should i click
you need to select "s/w upgrade"
