Page 4 of 33 FirstFirst 12345678914 ... LastLast
Results 46 to 60 of 486
  1. #46
    hello all sorry about this lookin im sorry about this question m8 but i live in a flat and im not aloud to put a sly for cs but i have being readin round the net and from wot i have read up on i think this krypt view a 780 well work on vm cs could you please put some light on it and thanks for ur time please pm and if so where the best place to buy 1 as i have read there clones out there
  2. #47
    Sep 2010
    Default Stuck Kryptview A780
    Please help I get a message at the below point after I have turned my box off and on and started the sending. In the box where it isw showing Data downloading 2%, I get an error message and the download fails. PLEASE HELP!! It's driving me mad
  3. #48
    Sep 2008
    Quote Originally Posted by pattersnic View Post
    more info needed,pc/laptop xp/vista serial port or usb.refollow the tut
  4. #49
    Mar 2009
    which type of null modem cable is it you need ie male to female or female to female????also is this the right ethernet cable
    Cat5e RJ45 Ethernet LAN Network Cable UTP Lead 20M
    any help much apprciated cheers mick
  5. #50
    Newbie veggie's Avatar
    Sep 2010
    Default Great guide
    As it says on the tin very good all up and running.
    Q- can i receive sky box office or any foreign channels for the 3,o,clock kick offs? if so do i need to manually find these through the box? any help will be greatly received.
  6. #51
    Sep 2008
    it wont allow hd as box not hd and box office you wont as are usually ordered through provider for their box,you should be able to watch the wrestling and boxing,and no foreign stations
  7. #52
    Sep 2010
    Default ok cheers
    it wont allow hd as box not hd and box you wont as are usually ordered through provider for their box,you should be able to watch the wrestling and boxing,and no foreign stations
    Ok thats solved that one looks like lappie or PC thanks.
  8. #53
    Jun 2009
    Hi all - just checking Kryptview out after a few years of Eurovox.
    Am I right in thinking that for all intents and purproses Kryptview works the same the only difference being that you connect the box to your router with an ethernet cable?
    Are you still able to browse the Net as usual while watching TV...daft question I know.
    I have a VM TV sub and BE broadband so all I'd need is the box, the cables and the firmware?
  9. #54
    Top Poster angrycat's Avatar
    Nov 2008
    Default No pin socket
    can i buy some sort of adapter as i dont have 9 PIN connection from my laptop?
  10. #55
    V.I.P. Member barrowmanandrew's Avatar
    scotland
    yes.. you are correct.
    the box will have no effect on your computer.
    you will need a null modem cable and possibly a usb to seriel adaptor, if your pc is newish....
  11. #56
    plasterer's Avatar
    Jun 2008
    Mersyside
    Yes thats correct mate ,all available
    Just read the red stickys at the top of the Kryptveiw Page ...Paul
    PAUL
  12. #57
    can you please help me ?
    are you saying if i purchase a kryptview a780 box i can get back all my virgin cable channels even though we are now on nag3???
    i was lead to believe that it was not possible to get them after nag3 was running!!!!
  13. #58
    scotland
    Quote Originally Posted by bigguy283 View Post
    yes you can, but not as straight forward as before...
    i suggest you have a good read around before parting with your hard earned cash...
  14. #59
    Sep 2010
    Quote Originally Posted by cactikid View Post
    hi krypt a780
    i have vista, trying to set up the box, however i cant find the port settings tab, can you help
    cheers
  15. #60
    Sep 2008
    Quote Originally Posted by davidelgie View Post
    hi krypt a780
    cheers
    better off trying to find a pc with xp and a serial port to flash box
