Page 5 of 33 FirstFirst 1234567891015 ... LastLast
Results 61 to 75 of 486
  1. #61
    Top Poster immi's Avatar
    Nov 2010
    london
    Default very very goog to understand even tho ido not have anytype of box.good to have imput.
    Quote Originally Posted by HiTeck View Post
    If you have a PC/Laptop with a 9 pin serial socket then all you need is a Null Modem Cable, see pic below.
    If you have a PC/Laptop that doesn't have the 9 pin serial socket you will need a Null Modem Cable and a USB adapter, See pic below.
    If you have a PC and you are struggling with the usb adapter or you have Vista like me you could install a PCI serial card which is easily added to you PC and with this all you need is the null modem cable which gives you a direct link from your box to the pc.
    Null Modem Com/Port setup Tutorial
    USB DB9 device coms/ports set up.
    Problems with your PC/Laptop not recognising your box.
    To see which port your USB adapter is connected to, connect your USB adapter and follow the following instructions:
    1. Go to the Start Menu
    2. Right click on "My Computer"
    3. Select "Properties"
    4. Click on the "Hardware" tab
    5. Click on "Device Manager"
    6. Click the + sign next to "Ports (COM & LPT)"
    7. One of the listed ports should indicate which port your USB adapter is connected to (e.g. COM1, COM2, COM3, etc.)
    8. Go back to your map software program that you use to transfer data and make sure it is looking at the correct port.
    9. You should be able to transfer data once the correct port is selected
    If you need drivers go here
    USB to Serial Adapter driver downloads and documentation
    Follow my advice to step 7. Locate your USB Adapter (port *)
    Right click on that port and select properties. Then select port settings, then select advanced. At the bottom of that tab will be a drop down box with the port selected (port * in your case). Use the drop down to select another port (eg 1, 2 or 3). If the port you want to use is already allocated to something else, you can use the same procedure to reassign that port after you have finished.
    Save the selections in the usual way. The USB converter will be permanently assigned to the port you selected.
  2. #62
    Nov 2010
    london
    need to know more.of how to set a systeme of the kryptview hd what will ineed to buy and where from.no to ebay buying please as i goot burnt big time
  3. #63
    Nov 2010
    london
    hi to everyone on d k.i am immi,i hope to make a lot of friends and be of help to the digital kaos members offering my free service from time to time on most make of motor cars mechanical wise,please do not mind the spellings.only offering to the members because of the site and that is digitalkaos.so if u got a probleme with ur car ,if near could also fix 4 free u buy ur carparts 1member at a time please as its getting could.
  4. #64
    Nov 2010
    Default how do you down load the Kryptview Loader
    how do you down load the Kryptview Loader?
  5. #65
    Quote Originally Posted by cityfan1964 View Post
    guys, just downloaded and flashed the firmware as per instructions. went into auto install and got nowhere with it...says it found 7 channels but will not go past installation screen. by the way i'm on nthell in waterford ireland. any help would be appreciated-thanks
    Great Tutorial.....
    A lot of problems people face with channel search is due to the fact that the flashing and subsequent isntallation (easy install) has to be done without the receiver being switched off.
    If after the flashing, the box is for some reason switched off (as in my case, i was flashing in a seperate room on my laptop and then carried the box to the room where my TV was), the installation to get channels would not work. The box can be switched off once the scan etc is complete.
  6. #66
    Sep 2008
    if you read up on it there are no boxes working in eire,only a doorstop m8.
  7. #67
    Nov 2010
    Smile
    Quote Originally Posted by boxboy View Post
    Can I use the STB Editor to edit my channels and then upload them to the box? If so, How? I have tried the send and recieve functions and nothing happens, the software tells me that the operation was not requested.
    yes same question here im new so im a little confused about this whole process
  8. #68
    Nov 2008
    N*L EIRE
    Post
    Quote Originally Posted by prince123 View Post
    I think you have to power-off box & power-on box after you hit
    send button to save channel list to P.C.
  9. #69
    Member Dj dee's Avatar
    Nov 2008
    Default KRYPTVIEW A780 - FILE LOADING
    Hi everyone
    I'm wondering if someone can come to my rescue.
    I have gone through the steps as illustrated on this thread, but could not load the file.
    I get a message "The downloading is not requested".
    I am using 2 cables (null famale to male cable & USB converter) with a small famale connector in between the cables. Nothing is happening.
    Could someone put some green light.
    I have checked the COM port.
    Would it be the cables?? I could not find a single cable.
    Your help will be much appreciated.
  10. #70
    Nov 2008
    N*L EIRE
    Post
    Quote Originally Posted by Dj dee View Post
    Hi everyone
    Turn off box. Hit start on loader. Turn on box
  11. #71
    Hi all just got my A780 today an looking on forum you make it look so easy so here goes,
  12. #72
    Newbie balmoral10's Avatar
    i tried downloading the firmware it is coming down as a bin file and will not let me open it can someone help please
  13. #73
    Sep 2008
    read the tut you dont open it.
  14. #74
    Default kryptview
    can this type of box be used on any type of broadband, talk,talk. etc, or is it strictly cable broadband
  15. #75
    Sep 2010
    hi mate iam new to all this i had a starview 5 box which has stopped working due to n3 iam on v/m in bristol if i buy a kriptview 780 box will it work and do i need a perminant internet connection , cheers
