xp pc does that have a com port rs232 null modem cable in box
to connect to rear of pc?
http://www.digital-kaos.co.uk/forums...09/index2.html
post 28 look at that
Yes. Tried it, but had the same results. Though that's assuming I'd done it correctly.
I'm on 7 but I think its similar in the device manager, never used Vista.
Plug you usb to serial in the usb on lappy, dont plug into box yet.
Click Start (Bottom Left)
Right click on Computer then click on manage
Click on Device manager
You should see Ports (com Ltp) to the right
Click on Ports (Com Ltp)
Usb to serial should appear with a port number (note the port number)
Right click it
Click on properties
It should say device working properly
Click on Port Settings at the top
Change the bit per second to 11200 data bits to 8 stop bits to 1
Press OK
Close all windows.
Open STB Loader and make sure the null cable is secure in back of box before entering the software and the correct port number you noted into the loader.
Yes, I think so. Only had 2 to choose from. The one does nothing, the other leads back to the same 'The downloading is not requested' message. Well, at least the way I had tried to do it.
did you install the drivers for the usb ??
was your box powered on when downloading was pressed
Thanks DW190. I'll try giving that a go, as that is something I don't remember having done. There maybe something there I've missed.
I've tried it from power right off, or from standby Cactikid. I've tried many things, but keep getting the same result
just chechecking that null modem cable came with the box yes
If one port is doing nothing and the other is doing something (download not requested) and your computer tells you the "device is working properly". Using the process of elimination, either the settings are wrong Bits & data bits or the null cable is not connecting.
You live anywhere near Bolton. Be easier to flash it for you than all this two finger typing.
No. Didn't get the cable with it. I already had that. The drivers are installed for the USB adapter too. I will go back over all of that though then, just to be sure. But both my laptop, and PC seem to end up saying the same things.
was this cable used to flash boxes if not,wrong cable
