Page 1 of 33 12345611 ... LastLast
Results 1 to 15 of 486
    V.I.P. Member HiTeck's Avatar
    Oct 2008
    Default Kryptview Firmware Loading Guide / Tutorial.
    If you have a PC/Laptop with a 9 pin serial socket then all you need is a Null Modem Cable, see pic below.
    If you have a PC/Laptop that doesn't have the 9 pin serial socket you will need a Null Modem Cable and a USB adapter, See pic below.
    If you have a PC and you are struggling with the usb adapter or you have Vista like me you could install a PCI serial card which is easily added to you PC and with this all you need is the null modem cable which gives you a direct link from your box to the pc.
    Null Modem Com/Port setup Tutorial
    USB DB9 device coms/ports set up.
    Problems with your PC/Laptop not recognising your box.
    To see which port your USB adapter is connected to, connect your USB adapter and follow the following instructions:
    1. Go to the Start Menu
    2. Right click on "My Computer"
    3. Select "Properties"
    4. Click on the "Hardware" tab
    5. Click on "Device Manager"
    6. Click the + sign next to "Ports (COM & LPT)"
    7. One of the listed ports should indicate which port your USB adapter is connected to (e.g. COM1, COM2, COM3, etc.)
    8. Go back to your map software program that you use to transfer data and make sure it is looking at the correct port.
    9. You should be able to transfer data once the correct port is selected
    If you need drivers go here
    USB to Serial Adapter driver downloads and documentation
    Follow my advice to step 7. Locate your USB Adapter (port *)
    Right click on that port and select properties. Then select port settings, then select advanced. At the bottom of that tab will be a drop down box with the port selected (port * in your case). Use the drop down to select another port (eg 1, 2 or 3). If the port you want to use is already allocated to something else, you can use the same procedure to reassign that port after you have finished.
    Save the selections in the usual way. The USB converter will be permanently assigned to the port you selected.
  2. The Following 6 Users Say Thank You to HiTeck For This Useful Post:
    ak1 (19th March, 2015), bickyz (11th July, 2015), dinga (15th August, 2014), pooliebell (17th January, 2014), stevestorm (30th May, 2016), user1957 (3rd November, 2014)
  3. #2
    Oct 2008
    Download and save both below to your PC/Laptop.
    Kryptview Loader is HERE.
    Kryptview Bin / Firmware is HERE.
    Run the Loader Pictured below Ref : 1.
    Click on the Download button Ref : 2.
    Once you have pressed the download button you will see another box load like below, Ref : 3.
    Press open and select the Bin file that you saved to your desktop earlier highlighted in yellow Ref : 4.
    Now turn off your Kryptview, press Start then turn the Kryptview back on. You should now see the firmware starting to load,
    Once done you will see this message,
    Once finished let the box reboot and then your done, congratulations.
  4. The Following 3 Users Say Thank You to HiTeck For This Useful Post:
  5. #3
    Aug 2008
    Default Channel Upload and download
    Can I use the STB Editor to edit my channels and then upload them to the box? If so, How? I have tried the send and recieve functions and nothing happens, the software tells me that the operation was not requested.
  6. #4
    guys, just downloaded and flashed the firmware as per instructions. went into auto install and got nowhere with it...says it found 7 channels but will not go past installation screen. by the way i'm on nthell in waterford ireland. any help would be appreciated-thanks
    V.I.P. Member wilf's Avatar
    Jan 2009
    uk
    Quote Originally Posted by cityfan1964 View Post
    have a read here mate there was a problem with someone else from waterford hope this help as im in uk and not much help to you
  8. #6
    hi wilf, is there a link to look at ? thanks for your help!!
  9. #7
    Jan 2009
    uk
    sorry buddy must have forgot to put it in. here it is http://www.digital-kaos.co.uk/forums...ireland-35908/
  10. #8
    Default Aftermath of Kryptview download
    Hi all, no channel is coming on after the download just this message "Complete exit". Pls help thanks
  11. #9
    Sep 2008
    Quote Originally Posted by mid View Post
    after any firmware is put on any box you need to factory reset 0000 to delete and rescan your provider.
  12. #10
    Have been on a number of forums to get the information but this is simply the best instructions. You should be writing instructions for a living ;-)
  13. #11
    Default Thanks for tutorial but have hit a snag - hope you can help
    Tutorial is excellent - clear and easy to follow. Unfortunately, I have hit what seems to be a common problem. I'm using a USB serial port adaptor/ null modem cable to connect to box but I'm getting the "The downloading is not requested" error in a pop up. There is a further error on the download popup "Read REQ failed". I've been through all the forums and have tried all suggestions. Would appreciate any help!
  14. #12
    Very clear and precise instructions. Have just ordered my box and can't wait to follow the instructions tomorrow. Will give feedback. Thanks a million
  15. #13
    could any one please help. I have downloaded the firmware, reset my box to default but still cannot receive the channels. It says scramble on most channels. Thanks
  16. #14
    Jan 2009
    uk
    have you checked in system info as to what firmware is on the box? anything later than 28/11/08 should be ok as long as you have scanned your box on the correct provider for your area
  17. #15
    Nov 2008
    can someone help me i am trying to put new firmware on to kryptview 700 just keeps coming up with "download is not requested"
