Page 1 of 32 12345611 ... LastLast
Results 1 to 15 of 486
Hybrid View
    V.I.P. Member HiTeck's Avatar
    Oct 2008
    Default Kryptview Firmware Loading Guide / Tutorial.
    If you have a PC/Laptop with a 9 pin serial socket then all you need is a Null Modem Cable, see pic below.
    If you have a PC/Laptop that doesn't have the 9 pin serial socket you will need a Null Modem Cable and a USB adapter, See pic below.
    If you have a PC and you are struggling with the usb adapter or you have Vista like me you could install a PCI serial card which is easily added to you PC and with this all you need is the null modem cable which gives you a direct link from your box to the pc.
    Null Modem Com/Port setup Tutorial
    USB DB9 device coms/ports set up.
    Problems with your PC/Laptop not recognising your box.
    To see which port your USB adapter is connected to, connect your USB adapter and follow the following instructions:
    1. Go to the Start Menu
    2. Right click on "My Computer"
    3. Select "Properties"
    4. Click on the "Hardware" tab
    5. Click on "Device Manager"
    6. Click the + sign next to "Ports (COM & LPT)"
    7. One of the listed ports should indicate which port your USB adapter is connected to (e.g. COM1, COM2, COM3, etc.)
    8. Go back to your map software program that you use to transfer data and make sure it is looking at the correct port.
    9. You should be able to transfer data once the correct port is selected
    If you need drivers go here
    USB to Serial Adapter driver downloads and documentation
    Follow my advice to step 7. Locate your USB Adapter (port *)
    Right click on that port and select properties. Then select port settings, then select advanced. At the bottom of that tab will be a drop down box with the port selected (port * in your case). Use the drop down to select another port (eg 1, 2 or 3). If the port you want to use is already allocated to something else, you can use the same procedure to reassign that port after you have finished.
    Save the selections in the usual way. The USB converter will be permanently assigned to the port you selected.
  2. The Following 6 Users Say Thank You to HiTeck For This Useful Post:
    ak1 (19th March, 2015), bickyz (11th July, 2015), dinga (15th August, 2014), pooliebell (17th January, 2014), stevestorm (30th May, 2016), user1957 (3rd November, 2014)
  3. #2
    Oct 2008
    Download and save both below to your PC/Laptop.
    Kryptview Loader is HERE.
    Kryptview Bin / Firmware is HERE.
    Run the Loader Pictured below Ref : 1.
    Click on the Download button Ref : 2.
    Once you have pressed the download button you will see another box load like below, Ref : 3.
    Press open and select the Bin file that you saved to your desktop earlier highlighted in yellow Ref : 4.
    Now turn off your Kryptview, press Start then turn the Kryptview back on. You should now see the firmware starting to load,
    Once done you will see this message,
    Once finished let the box reboot and then your done, congratulations.
  4. The Following 3 Users Say Thank You to HiTeck For This Useful Post:
  5. #3
    Jul 2009
    guys, just downloaded and flashed the firmware as per instructions. went into auto install and got nowhere with it...says it found 7 channels but will not go past installation screen. by the way i'm on nthell in waterford ireland. any help would be appreciated-thanks
  6. #4
    V.I.P. Member wilf's Avatar
    Jan 2009
    uk
    Quote Originally Posted by cityfan1964 View Post
    have a read here mate there was a problem with someone else from waterford hope this help as im in uk and not much help to you
  7. #5
    Jul 2009
    hi wilf, is there a link to look at ? thanks for your help!!
  8. #6
    Jan 2009
    uk
    sorry buddy must have forgot to put it in. here it is http://www.digital-kaos.co.uk/forums...ireland-35908/
  9. #7
    Nov 2009
    Great Tutorial.....
    A lot of problems people face with channel search is due to the fact that the flashing and subsequent isntallation (easy install) has to be done without the receiver being switched off.
    If after the flashing, the box is for some reason switched off (as in my case, i was flashing in a seperate room on my laptop and then carried the box to the room where my TV was), the installation to get channels would not work. The box can be switched off once the scan etc is complete.
  10. #8
    Feb 2010
    Default kryptview a750 Receive
    How Can i Receive code from my kryptview a750 i got latest firmware
  11. #9
    Sep 2010
    Default Stuck Kryptview A780
    Please help I get a message at the below point after I have turned my box off and on and started the sending. In the box where it isw showing Data downloading 2%, I get an error message and the download fails. PLEASE HELP!! It's driving me mad
  12. #10
    Sep 2008
    Quote Originally Posted by pattersnic View Post
    more info needed,pc/laptop xp/vista serial port or usb.refollow the tut
  13. #11
    Mar 2009
    which type of null modem cable is it you need ie male to female or female to female????also is this the right ethernet cable
    Cat5e RJ45 Ethernet LAN Network Cable UTP Lead 20M
    any help much apprciated cheers mick
  14. #12
    Sep 2010
    Quote Originally Posted by cactikid View Post
    hi krypt a780
    i have vista, trying to set up the box, however i cant find the port settings tab, can you help
    cheers
  15. #13
    Sep 2008
    Quote Originally Posted by davidelgie View Post
    hi krypt a780
    cheers
    better off trying to find a pc with xp and a serial port to flash box
  16. #14
    Dec 2011
    hi i am getting an error message the download is not requested... Any ideas?
  17. #15
    Dec 2011
    please help...
