Results 1 to 4 of 4
    Top Poster BrunoJ's Avatar
    Jul 2013
    At Home
    Lightbulb Xtrend Et4000 Stuck!
    Hi have a Xtrend ET4000 and is stuck on the display with a Green and Red light? Any ideas? Try to flash it with USB and still no luck.
    Many thanks in advance for any help.
    Gods Country - Liverpool
    When you flash from USB make sure the usb stick is formatted correctly. Then disconnect any other usb sticks that you may have plugged in.
    Also, it may be worth installing the latest bootloader? Use the ViX Image shouldnt have any problems. Good luck.
    FP.
    Jul 2013
    At Home
    Quote Originally Posted by flyingpig View Post
    FP.
    USB flash drive (FAT32 formatted)
    USB device (E.g. USB memory stick) In the root directory, create a folder et4x00 and copy the following 5 files to that location
    Boot.bin
    kernel.bin
    rootfs.bin
    imageversion
    noforce ( "force" for automatic Flash.)
    This is what i been doing and still no luck.
    which usb port are you using
    I found that front one works better
