I have the traveler one written up, Post pictures, and I'll post the script (Front, back, PCB, sticker)
zckariya70 (4th March, 2015)
i have uplodead the tempo traveller force pictures
Here you go
a2000 (19th July, 2015), DashProg (6th January, 2016), hoangtu (25th August, 2015), ivica21 (12th March, 2015), Jashmine1983 (7th June, 2015), juancho18 (14th March, 2016), lion0304 (22nd July, 2015), maruti (5th September, 2016), pintu (3rd February, 2016), stefaudio (29th January, 2015), zckariya70 (4th March, 2015)
how to select 95160 in Etsmart
u there Rerouter ?
25160, I would not know where it would be for yours as i have since cleared mine out,
gjuzel (29th January, 2015), stefaudio (29th January, 2015), zckariya70 (4th March, 2015)
ok thank u Re router
hi Rerouter in that posted dump ur file is working perfectl and shows the orginal km but in another dump it shows the orginal km 0 the calculator cant read the orginal km if i change the km it changes the orginal location
It was not intended to read or write less than 8km,
let me guess that in the 0km dump, 0x380-0x3FF is all 0xFF, which breaks my test,
There is nothing else i can knowingly test in the file to say its valid, so you will just have to live with that limitation,
ok Rerouter thank u
bolero 24c08 eeprom need etsmart script 2012 model
Try this and see that it works, if it does i should be able to write him up,
At a good guess it looks like this cluster has hours as well, an algo that i am aware of but do not yet fully know how to calculate, current value back to dec is 169928 if you could look if you can see hours, might help complete the job,
A file for feedback, This is all that is asked on this site, Did it work? what value appeared on the dash? maybe some photos or a power-up,
hoangtu (25th August, 2015), maruti (10th September, 2016), stefaudio (29th January, 2015), zckariya70 (29th January, 2015)
u can c the dump km is stored in the line 3A0-3B0 02 97 is wand to be changed that is km dont want to calculate in hours i need km that location is km
