Page 2 of 14 FirstFirst 123456712 ... LastLast
Results 16 to 30 of 201
  1. #16
    Nov 2008
    Ive made a suggestion to digidude but dunno if its appropriate.
    But I followed the guide as best can and done well but when it came to the actual mounting of the satelite was stuck, seems you cant just use any drill for drilling into concrete/stone/brick !
    After speaking too a builder with experience hes advised me of a heavy duty Hammer Drill and ill require a masonry set also, masonry set can get thru brick/concrete/stone surfaces.
    I maybe wrong about this but id guess most folk are gonna mount there kit against a solid fixture (stone/brick/concrete) and not a wood !
    I think it would be nice too have it part of the guide otherwise people will just get stuck half way thru like myself
  2. #17
    Default top marks
    Top marks for effort ,spot on ,just wondered ,i have fitted a 1mtr motorised dish but in my location[ north west] it cant see above 19 deg astra so ,on the front of house i have a sly minidish for 28 deg and a separate feed to back or receiver
    is it simple enough to wire a splitter to switch between dishes as i dont wavt the motorised dish to move when i select 28 deg?
  3. #18
    safc1234
    Guest
    Default safc
    do you no where i ca n get a motorised set up pleas,
  4. #19
    Top Poster plamen.1973's Avatar
    London
    Quote Originally Posted by safc1234 View Post
    Maybe this can you help?
  5. #20
    the darkside of the moon
    Fantastic post there, Its now got me thinking about having a go my self as Ive been quoted ?130 but this includes T&K bracket, pole, dish and L.N.B, cable AND fitting so I don't know if Im being a tight ass as that seems to me to be a knockdown price and I wont even have to get the ladders out!!
  6. #21
    DK Veteran standarren's Avatar
    Jun 2008
    BIRMINGHAM
    help guys i cant find thor
    when i point the dish at due south then input vmy position the dish points back at the house something doesnt seem right i've got the dish on the same south facing wall as a sky dish
  7. #22
    V.I.P. Member thered's Avatar
    Aug 2008
    Quote Originally Posted by standarren View Post
    can you find others
  8. #23
    Jun 2008
    BIRMINGHAM
    Quote Originally Posted by thered View Post
    can you find others
    yes think i can find the sky sat but cant be 100%
    is there any other guides i can use what have i done wrong
  9. #24
    Bulld0g's Avatar
    Apr 2008
    Liverpool
    Not all sky dishes are on a south facing wall. Use a compass to make sure your dish is on a south facing wall
  10. #25
    Aug 2008
    where have you got too its possible to find all satellites from sky
  11. #26
    Jun 2008
    BIRMINGHAM
    Quote Originally Posted by Bulld0g View Post
    i cant seem to find thor on dishpointer
    i'm sure its pointing in the correct position
  12. #27
    Aug 2008
    in your arc can you get hotbird 13e and astra 19.2e as well as astra (sky 28.2)
  13. #28
    Bulld0g's Avatar
    Apr 2008
    Liverpool
    My mate had his dish on the same wall as his sky dish. When i went to set it up for him because he was having trouble getting a signal, the dish was on the wrong wall. Get a compass or a satnav and make sure its on a south facing wall
  14. #29
    Jun 2008
    BIRMINGHAM
    yes can get all of them
  15. #30
    Aug 2008
    ok so when your dish spins round from say 28 to 13 how far from your wall is the dish getting closer to wall
