Page 15 of 15 FirstFirst ... 5101112131415
Results 211 to 218 of 218
  1. #211
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    Quote Originally Posted by deanlecky View Post
    I have flashed my DM500s clone with a gemini image, everything worked during the dreamup and flashing process, it installed without any problems.
    But when I turn the box on nothing appears on the screen, its like its not booting up.
    What have I done wrong?
    ld try another image the commando 14.6 is the best
  2. #212
    Sep 2012
    thanx alot for this guide#
  3. #213
    Sep 2010
    Hi Guys, bit of a newbie but have carried out this task before!!. DM550S just stopped working??? so thought I would carry out a reflash as per instructions above. Connect unit to PC via null modem, open 'Dreamup' press "connect", switch on the power and ......nothing. Box does not say "connected" in readiness to upload image....Any ideas, is my box bricked???
    Any help would be greatly appreciated.....
    Jezreel
  4. #214
    Apr 2013
    Hi, Guys I need some help.I tried to flash a new 500s yesterday and connected a null modem cable.it went to the' Connection prepared,now switch on the dreambox' stage and nothing else. I tried to reconnect afew times but no joy.Now the DB doesn't switch on any more.Have I wrecked it.Is there any thing I can do? Thanks in advance.Using Dream up 1.3.3.6
  5. #215
    DK Veteran psats's Avatar
    Sep 2008
    Quote Originally Posted by anarchy83 View Post
    use 1321 or 1322
  6. #216
    Nov 2008
    wont let me download files all i get is black screen help
  7. #217
    Jun 2014
    Default thankssssssss
    [QUOTE=Devilfish;217222]How Do I Use Dreamup?
    If, for any reason, your box won't boot, you will have to use Dreamup to flash an image instead of Flash Wizard Pro or any other method. You won't be able to connect via ethernet so no ip address is required. It may be that the process simply hung up during flashing or you accidentally pulled the plug half way through (yes it did happen to me). This will get you back on track.
    Required
    • Null Modem Cable (this is NOT the same as a serial or rs232 cable, although it looks the same)
    • Image File (.img)
    • DreamUp Program
    Instructions
    • Disconnect all cables from your dreambox, including the power
    • Connect the null modem cable to the dreambox and to your PC
    • Load Dreamup.exe
    • Click Connect and you will see a message like this
    • Connect the power and the bootloader should be copied to the box
    • The message should now say 'Box attached and Ready'
    • Click Flash on the right hand side and select the image to be flashed
    • Click Yes or Ya (depending on the version)
    Note: If you're flashing a backup image, select NO.
    • The image should then be uploaded to the box
    • There will be a countdown timer at the bottom of the program
    • After the image is uploaded, it will be flashed to memory
    • The finished process should look like this:
    • Click OK and close down Dreamup
    • Power off the dreambox for 30 seconds then power up
    • If any errors appear, check all cables are connected properly and repeat the process but do not use the PC while it's running
    Good Luck![
    thank youuuuuuuuuuuuuuu
  8. #218
    Feb 2013
    Hi, I need a bit of help please, I have my DM500s flashed with Null Modem Cable.
    I need to know what do I do next. could you please step me through the next stages please.
    Thanks.
